Oven won't even turn on
The racks in my oven keep falling (I think the oven walls have expanded over the years), and they fell
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven won't even turn on
  #1 (permalink)
Old 03-07-2013, 10:35 AM
Junior Member
mommaluca is on a distinguished road
Default Oven won't even turn on
Model Number: 790.47832403   Brand: Kenmore   Age: 5 - 10 years
The racks in my oven keep falling (I think the oven walls have expanded over the years), and they fell recently, spilling a large amount of butter onto the oven floor. I cleaned it up as much as I could and then set it on a short self-clean cycle. About a half hour into it, I got an F10 error code and had to cut the power. Once it cooled down, I was able to open it. However now it won't turn on. Not the oven, broiler, or fan. The clock and panel appear to be working normally, but neither the oven, broiler, or fan will turn on. The panel says its on, but nothing happens.
Any ideas? And is something I could do myself? I have to wonder if it's worth it, with the wonky sides/racks. I have no experience.
Thank you so much!
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 03-08-2013, 03:13 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Parts for Kenmore Wall Oven 79047832403 - AppliancePartsPros.com
If you go to the sears parts site they have actual parts breakdowns.
Unfortunately they do not share these with other parts suppliers like AppliancePartsPros.
The elements and the fan relay all require 240 volts so L2 voltage may be missing.
Check that the unit is getting 240 volts where it attaches to the house wiring.
F10 comes up as a temperature runaway.
It may have blown the thermal safety thermostat.
It is mounted at the back outside of the oven.
Will look like the below.
Part number: AP2126993
Click on it's picture for more info/views about the part.
Note if yours has the red button on the back and it is popped out push it in to reset it.
Be sure that you shut power off to the unit when working on it.
Check the safety thermostat with a meter, it should be 0 ohms at room temperature.
If it is popped or bad you will have to check the oven sensor to be sure that it did not cause a temperature run away. Below is a good link, look at 7, 8, 20 and 21.
To be honest unless you can come up with a way to ensure that the racks do not fall I would scrap the unit. This is very dangerous.
Looks like the side walls of this unit are separate items, perhaps you could put a washer or two behind them so the are closer together.
  #3 (permalink)
Old 03-09-2013, 01:56 PM
Junior Member
Thanks so much, denman! I am checking out your links and will see what I can do. Great idea about the walls.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool oven code F3 63 oven won't turn on lkaymen Oven Repair (including Ranges and Cooktops) 9 09-26-2013 06:38 AM
turn oven on glow plug come on but oven won't come on freejans Oven Repair (including Ranges and Cooktops) 0 03-19-2012 05:26 AM
oven turn off Bear1 Oven Repair (including Ranges and Cooktops) 0 05-21-2011 08:06 PM
Oven light won't turn off/microwave and oven don't heat Luda Oven Repair (including Ranges and Cooktops) 0 07-23-2010 10:26 PM
Maytag Stove/Oven - oven will not turn off bodnarja Oven Repair (including Ranges and Cooktops) 6 11-01-2009 02:23 AM
