Discuss
GE Oven Element will not heat up to orange glow
 in
The bake element broke in my oven. I repalced the element, but it still would not heat up. I then
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Oven Element will not heat up to orange glow
  #1 (permalink)
Old 03-07-2013, 11:11 AM
Junior Member
Northharfordhawks is on a distinguished road
Default GE Oven Element will not heat up to orange glow
Model Number: JHP 70N OK2   Brand: GE   Age: More than 10 years
The bake element broke in my oven. I repalced the element, but it still would not heat up. I then replaced the oven switch, part WB22X5122, now the oven will heat up, but not to the point where the element should be glowing orange. It is just very hot to the touch, that's all. When I put the oven switch to bake time, the bake element will glow bright orange, but again, not in the bake setting. Any help on this problem is appreciated.
Jay
Related Models
Maytag JHP1060 JADE HOT PLATES (COOKING GAS)
Maytag JHP112 JHP HOT PLATE (COOKING GAS)
Maytag JHP212 JHP HOT PLATE (COOKING GAS)
Maytag JHP224 JHP HOT PLATE (COOKING GAS)
Maytag JHP336 JHP HOT PLATE (COOKING GAS)
Maytag JHP424 JHP HOT PLATE (COOKING GAS)
Maytag JHP448 JADE HOT PLATES (COOKING GAS)
General Electric JHP56*D1 Hi-low range
General Electric JHP56*V8 Hi-low range
General Electric JHP56*VA Hi-low range
General Electric JHP56G*C1 Hi-low range
General Electric JHP56G*D1 Hi-low range
General Electric JHP56G*D2 Hi-low range
General Electric JHP56G*D3 Hi-low range
General Electric JHP56G*H1 GE HI/LOW COOKING CENTER
General Electric JHP56G*H2 Hi-low range
General Electric JHP56G*J1 Hi-low range
General Electric JHP56G*J2 Hi-low range
General Electric JHP56G*J3 Hi-low range
General Electric JHP56G*M1 Hi-low range
General Electric JHP56G*V6 Hi-low range
General Electric JHP56GN1 Hi-low range
General Electric JHP56GN2 Hi-low range
General Electric JHP56GN3AD Electric range
General Electric JHP56GN3WH Electric range
General Electric JHP56GN4AD Electric range
General Electric JHP56GN4WH Electric range
General Electric JHP56GN5AD Electric range
General Electric JHP56GN5WH Electric range
General Electric JHP56GN6AD Electric range
General Electric JHP56GN6WH Electric range
General Electric JHP56GN7AD Electric range
General Electric JHP56GN7WH Electric range
General Electric JHP56N*K1 Hi-low range
General Electric JHP56N*K2 Hi-low range
General Electric JHP56N*K3 Hi-low range
General Electric JHP56N*K4 Hi-low range
General Electric JHP56V*K1 Hi-low range
General Electric JHP56V*K2 Hi-low range
General Electric JHP56V*K3 Hi-low range
General Electric JHP56V*K4 Hi-low range
General Electric JHP60G*01 Hi-low range
General Electric JHP60G*02 Hi-low range
General Electric JHP60G*03 Hi-low range
General Electric JHP60G*04 Hi-low range
General Electric JHP61G*H2 Hi-low range
General Electric JHP61G*J1 Hi-low range
General Electric JHP62G*M1 Hi-low range
General Electric JHP62GN1 Electric range
General Electric JHP62GN2 Hi-low range
General Electric JHP62GN3AD Electric range
General Electric JHP62GN3WH Electric range
General Electric JHP62GN4AD Electric range
General Electric JHP62GN4WH Electric range
General Electric JHP62GN5AD Electric range
General Electric JHP62GN5WH Electric range
General Electric JHP62GN6AD Electric range
General Electric JHP62GN6WH Electric range
General Electric JHP62N*K1 Hi-low range
General Electric JHP62N*K2 Hi-low range
General Electric JHP62N*K3 Hi-low range
General Electric JHP62N*K4 Hi-low range
General Electric JHP62N*K5 Hi-low range
General Electric JHP62V*K1 Hi-low range
General Electric JHP62V*K2 Hi-low range
General Electric JHP62V*K3 Hi-low range
General Electric JHP62V*K4 Hi-low range
General Electric JHP62V*K5 Hi-low range
Maytag JHP636 JADE HOT PLATES (COOKING GAS)
General Electric JHP63G*H1 Hi-low range
General Electric JHP63G*J1 Hi-low range
General Electric JHP63G*J2 Hi-low range
General Electric JHP63G*J3 Hi-low range
General Electric JHP63G*M1 Hi-low range
General Electric JHP63GN1 Electric range
General Electric JHP63GN2 Hi-low range
General Electric JHP63GN3AD Electric range
General Electric JHP63GN3WH Electric range
General Electric JHP63GN4AD Electric range
General Electric JHP63GN4WH Electric range
General Electric JHP63GN5AD Electric range
General Electric JHP63GN5WH Electric range
General Electric JHP63V*K1 Hi-low range
General Electric JHP63V*K2 Hi-low range
General Electric JHP63V*K3 Hi-low range
General Electric JHP63V*K4 Hi-low range
General Electric JHP63V*K5 Hi-low range
General Electric JHP64G*L1 Hi-low range
General Electric JHP64V*L1 Hi-low range
General Electric JHP65G*01 Hi-low range
General Electric JHP65G*02 Hi-low range
General Electric JHP65G*D1 Hi-low range
General Electric JHP66G*01 Hi-low range
General Electric JHP66G*02 Hi-low range
General Electric JHP67G*D1 Hi-low range
General Electric JHP67G*D2 Hi-low range
General Electric JHP67G*D3 Hi-low range
General Electric JHP67G*H1 GE HI/LOW COOKING CENTER
General Electric JHP67G*H2 Hi-low range
General Electric JHP67G*V5 Hi-low range
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
General Electric JHP69G*K2 Hi-low range
General Electric JHP69G*K3 Hi-low range
General Electric JHP69G*K4 Hi-low range
General Electric JHP69G*K5 Hi-low range
General Electric JHP69GN1 Hi-low range
General Electric JHP69GN2 Hi-low range
General Electric JHP69GN3AD Electric range
General Electric JHP69GN3WH Electric range
General Electric JHP69GN4AD Electric range
General Electric JHP69GN4WH Electric range
General Electric JHP70G*M1 Hi-low range
General Electric JHP70GN1 Hi-low range
General Electric JHP70GN2 Hi-low range
General Electric JHP70GN3AD Electric range
General Electric JHP70GN3WH Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
orange glow in my microwave Roland C Microwave Repair 0 10-02-2011 11:11 AM
Gas dryer orange glow Alex82 Dryer Repair 0 04-06-2010 03:23 AM
HOT orange glow frezrbrn23 Refrigerator & Freezer Repair 6 11-11-2009 07:36 AM
GE Gas oven won't preheat - no orange glow Dopher Oven Repair (including Ranges and Cooktops) 1 08-18-2009 01:42 PM
Bad? orange glow behind freezer, noises htowncoog Refrigerator & Freezer Repair 2 06-10-2008 09:39 AM
