Discuss
Oven/ stove top not working
 in
Elements on stove top not working. Oven not working. Checked breakers , on . Checked each leg under small door
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven/ stove top not working
  #1 (permalink)
Old 03-05-2013, 07:25 PM
Junior Member
TubeCarz is on a distinguished road
Default Oven/ stove top not working
Model Number: RF364PXYN1   Brand: Whirlpool   Age: More than 10 years
Oven not working.
Checked each leg under small door bottom L.H. corner ( hot )
Pulled inspection cover behind control panel .
Waiting on instructions ...
Ads By Google
Related Models
Whirlpool RF364PXYN1
Whirlpool RF364PXYN2
Whirlpool RF364PXYN3
Whirlpool RF364PXYQ0
Whirlpool RF364PXYQ1
Whirlpool RF364PXYQ2
Whirlpool RF364PXYQ3
Whirlpool RF364PXYW0
Whirlpool RF364PXYW1
Whirlpool RF364PXYW2
Whirlpool RF364PXYW3
Whirlpool RF365BXPN0
Whirlpool RF365BXPN1
Whirlpool RF365BXPW0
Whirlpool RF365BXPW1
Whirlpool RF365BXVN0
Whirlpool RF365BXVW0
Whirlpool RF365BXWM1
Whirlpool RF365BXWM2
Whirlpool RF365BXWN0
Whirlpool RF365BXWN1
Whirlpool RF365BXWN2
Whirlpool RF365BXWW0
Whirlpool RF365BXWW1
Whirlpool RF365BXWW2
Whirlpool RF365BXYN0
Whirlpool RF365BXYN1
Whirlpool RF365BXYW0
Whirlpool RF365BXYW1
Whirlpool RF365EXPW0
Whirlpool RF365EXPW1
Whirlpool RF365PXDN0
Whirlpool RF365PXDQ0
Whirlpool RF365PXDW0
Whirlpool RF365PXDZ0
Whirlpool RF365PXGN0
Whirlpool RF365PXGN1
Whirlpool RF365PXGQ0
Whirlpool RF365PXGQ1
Whirlpool RF365PXGT1
Whirlpool RF365PXGW0
Whirlpool RF365PXGW1
Whirlpool RF365PXKQ0
Whirlpool RF365PXKT0
Whirlpool RF365PXKV0
Whirlpool RF365PXKW0
Whirlpool RF365PXMQ0 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMQ1 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMQ2 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMQ3 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMT0 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMT1 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMT2 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMT3 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMV0 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMV1 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMV2 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW0 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW1 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW2 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW3 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXWN0
Whirlpool RF365PXWW0
Whirlpool RF365PXXN0
Whirlpool RF365PXXN1
Whirlpool RF365PXXN2
Whirlpool RF365PXXW0
Whirlpool RF365PXXW1
Whirlpool RF365PXXW2
Whirlpool RF365PXYN0
Whirlpool RF365PXYN1
Whirlpool RF365PXYN2
Whirlpool RF365PXYQ0
Whirlpool RF365PXYQ1
Whirlpool RF365PXYQ2
Whirlpool RF365PXYW0
Whirlpool RF365PXYW1
Whirlpool RF365PXYW2
Whirlpool RF365PXYZ2
Whirlpool RF3661XDN0
Whirlpool RF3661XDW0
Whirlpool RF3663XDN0
Whirlpool RF3663XDW0
Whirlpool RF366BXDN0
Whirlpool RF366BXDN1
Whirlpool RF366BXDW0
Whirlpool RF366BXDW1
Whirlpool RF366BXVN0
Whirlpool RF366BXVN1
Whirlpool RF366BXVN2
Whirlpool RF366BXVN3
Whirlpool RF366BXVW0
Whirlpool RF366BXVW1
Whirlpool RF366BXVW2
Whirlpool RF366BXVW3
Whirlpool RF366LXKQ0
Whirlpool RF366LXKT0
Whirlpool RF366PXDN0
Whirlpool RF366PXDQ0
Whirlpool RF366PXDW0
Whirlpool RF366PXDZ0
Whirlpool RF366PXGN0
Whirlpool RF366PXGN1
Whirlpool RF366PXGQ0
Whirlpool RF366PXGQ1
Whirlpool RF366PXGQ2
Whirlpool RF366PXGT1
Whirlpool RF366PXGT2
Whirlpool RF366PXGW0
Whirlpool RF366PXGW1
Whirlpool RF366PXGW2
Whirlpool RF366PXXB0
Whirlpool RF366PXXB1
Whirlpool RF366PXXB2
Whirlpool RF366PXXN0
Whirlpool RF366PXXN1
Whirlpool RF366PXXN2
Whirlpool RF366PXXQ0
Whirlpool RF366PXXQ1
Whirlpool RF366PXXQ2
  #2 (permalink)
Old 03-06-2013, 02:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool RF364PXYN1 Range - AppliancePartsPros.com
See the attachment for the wiring diagram.
Since the oven and stove top circuits in the unit are mostly separate it sounds like a power problem.
How did you do the above?
You must use a meter.
Checking for 120 to the frame/neutral on each side of the line not good enough. You have to check for 240 volts between L1 and L2.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 03-06-2013, 03:33 PM
Junior Member
Default
Denman,
As much as I hate to admit it. I had a bad breaker .. Intermit ... OK , it was bad .. LOL
Thank you for your help !
Whirlpool live's to cook another day !
  #4 (permalink)
Old 03-07-2013, 02:13 AM
Senior Expert
APP Volunteer
Default
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
stove and oven not working cindye Oven Repair (including Ranges and Cooktops) 0 07-05-2011 09:12 AM
GE Stove Oven Not Working SteveHRP Oven Repair (including Ranges and Cooktops) 1 05-27-2010 09:29 PM
Oven not working, stove is ok vinh_golf Oven Repair (including Ranges and Cooktops) 0 11-13-2009 03:22 PM
Oven and broiler not working in gas stove grobinson43 Oven Repair (including Ranges and Cooktops) 0 03-16-2009 08:47 AM
oven not working but stove top is cdickson71728 Oven Repair (including Ranges and Cooktops) 1 01-03-2009 08:44 PM
