| » Jenn Air over heating cant turn it off |
Model Number: WW30430W Brand: Jenn-Air Age: 5 - 10 years
Oven would not stop heating
Pressed cancel still heating Had to turn breaker off Is it he Temp Sensor --- or the control board how can you test for it Ads By Google Related Models Last edited by sgoold2002@gmail.com : 03-04-2013 at 10:37 AM. |
Hello,
The problem is a bad oven relay board. Because you did not mention which oven does not work I will post for you both part numbers. They both located behind the control panel. - The upper oven relay board Part number: 74006613 - The lower oven relay board Part number: 12001914 Here are the breakdown diagrams and Parts for Jenn-Air WW30430W Wall Oven - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
I don't think you can just pull it out. More likely the control will sense it.
I'm not sure on which side it is but you will definitely see the difference as soon as you will open it up. Also APP has this part in stock and you can have it in 2-3 days. Gene.
__________________
You said earlier
Quote:
Quote:
So what exactly is wrong? Click on the part number above to see the pictures. I don't have pictures with the wires attached. Why do you need it? Gene.
__________________
| Display Modes | |
| Jenn Air Over Won't Turn Off | Chump Cycles | Oven Repair (including Ranges and Cooktops) | 1 | 10-25-2010 05:20 AM |
| Jenn Air won't turn on | dtaylo3 | Oven Repair (including Ranges and Cooktops) | 1 | 05-06-2009 04:08 AM |
| Jenn-Air oven will not turn off | teegee | Oven Repair (including Ranges and Cooktops) | 2 | 03-14-2009 05:25 AM |
| Jenn Air fan comes on when turn on burner | lapgkott | Oven Repair (including Ranges and Cooktops) | 2 | 12-13-2008 05:04 AM |
| Jenn air won't turn off | rdrye | Trash Compactor Repair | 1 | 09-04-2008 11:49 AM |
