| » Oven bake element works sometimes |
Hi.
Using the multimeter check for the 240VAC across the bake element contacts with the oven turned to BAKE. If the correct voltage is present - replace the element. If not - provide the model number of the oven for the research. Post the results. Simon. PS. Be careful, the 240VAC could be very dangerous.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I took the element to a parts shop & they suggested replacement so i did. Worked great. Put the oven back together, tried it again and nothing. Checked connections all seem tight. Dont have a multimeter. Now sometimes it gets warm but not warm enough,sometimes nothing, once in a while glows red. Switch going bad? Thermostaat issue? Any ideas are appreciated.
Hi.
To be a true DIY you should have a basic tools, including the multimeter.That will save you time and money. To give you any future advise I'd love to have the complete model number of the unit. Thank you. Simon.
__________________
Hi.
If the wire harness at the back of the oven is OK - replace the oven control board Part number: AP2632445 Post the results. Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| GE oven bake element not working, broil works. | HelpMeAnyone | Oven Repair (including Ranges and Cooktops) | 1 | 12-25-2011 05:03 PM |
| Replaced burner element now bake nor broil works. | Russell79 | Oven Repair (including Ranges and Cooktops) | 3 | 06-09-2010 06:24 AM |
| bake element blew now nothing works | GeorgiaM | Oven Repair (including Ranges and Cooktops) | 3 | 12-25-2009 04:18 AM |
| Wall oven bake element not working! Broil works, clock works. | ajachyra | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2009 06:30 AM |
| Replaced bake element; now nothing works but clock | JK030150 | Oven Repair (including Ranges and Cooktops) | 3 | 01-10-2008 04:02 PM |
