Our oven was not baking correctly so after some testing, I noticed the oven would heat up to temp and continue to show 350, no problem. If I cancel bake and reset to 350, the temp would only be 280 or so. Cleaned the oven by hand and found the baking element had some bubbling, so I got a new one and installed it. Same problem, so I got a new sensor. That fixed the temp issue but the oven is only using the broil element to heat, the bake element doesn't get hot. Hoping I don't need a new controller. The one thing I don't know is if both elements are used to heat the oven when baking. Not sure why the broiler would be coming on for baking if it is only for broiling.
