| » GE oven-Clock/temp not showing |
Model Number: jrs06bjbb Brand: GE Age: Less than 1 year
Hello,
Just moved into new house and encountered a weird oven. All of the buttons make sound when I press them and the heat comes on. When I hit "bake" then + a single digit will appear and go from 0-9 when I hit + or -. There is no clock or actually temperature given. It's like the right side of the display isn't working. Any advice or help would be greatly appreciated. Thanks! Ads By Google Related Models |
Hello,
Most likely the problem is a bad control board. There are no instrumental tests to verify it but there is nothing else what can cause it. It is recommended to order the faceplate together with the control board because it's adhered to the board. - The control board Part number: WB27T10495 - The faceplate Part number: WB27T10589 Here are the breakdown diagrams and Parts for GE JRS06BJ1BB Wall Oven - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven Clock has faded and temp is black | gailrr | Oven Repair (including Ranges and Cooktops) | 0 | 08-27-2009 02:39 PM |
| Temp light and clock has become very dim, suddenly | riedel264@gmail.com | Oven Repair (including Ranges and Cooktops) | 1 | 11-28-2008 09:06 AM |
| timer, clock, over temp etc. so dim they can't be read | fpontarolo | Oven Repair (including Ranges and Cooktops) | 1 | 10-13-2008 01:10 PM |
| Dim Panel Display (Clock, Temp) | majestik | Oven Repair (including Ranges and Cooktops) | 3 | 01-02-2008 05:08 PM |
| Clock Assembly or Temp Sensor? | Joyce | Oven Repair (including Ranges and Cooktops) | 5 | 10-20-2007 01:07 PM |
