patruttle
#1 Posted : Thursday, February 28, 2013 9:39:02 AM(UTC)
patruttle
Oven won't heat
#2 Posted : Friday, March 1, 2013 2:59:41 AM(UTC)
Parts for Frigidaire CPEB30S9FC3 Wall Oven - AppliancePartsPros.com
Here is the wiring diagram.
http://manuals.frigidaire.com/p...assomption/318046235.pdf
First check that the unit is getting 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK check the safety thermostat.
If it has a red button on the back that has popped out it may just have to be reset.
If it is blown it is a good idea to check your oven sensor.
