Discuss
oven wouldn't heat to set temperature and now does not seem to ignite oven gas burner
 in
The range top burners and broiler work. The oven would not heat above 250 degrees. We replaced the sensor and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven wouldn't heat to set temperature and now does not seem to ignite oven gas burner
  #1 (permalink)
Old 02-27-2013, 01:33 PM
Junior Member
Lori001 is on a distinguished road
Default oven wouldn't heat to set temperature and now does not seem to ignite oven gas burner
Model Number: FGFLM55GCC   Brand: Frigidaire   Age: 1 - 5 years
The range top burners and broiler work. The oven would not heat above 250 degrees. We replaced the sensor and ignitor. Yesterday after replacing the ignitor that we purchased from Appliancepartspro.com, the oven heated to 350 degrees but only after 30 minutes. This morning I tried again and the flame lit but only heated to 275 degrees. I turned the oven off, let cool and tried again. That is when the oven gas flame would not light. I saw the glow of the ignitor but did not hear the gas click on like it did earlier. I think it may be the gas valve but everything I've read says it is unlikely. If it is the gas valve I am not sure what part to order. I think it might be 316404901. Help the oven is only 3 years old! We are at our wits end.
Thank you.
Related Models
Frigidaire FGFLMC55ECA Frigidaire/gas Range
Frigidaire FGFLMC55ECB Frigidaire/range
Frigidaire FGFLMC55ECC Frigidaire/range
Frigidaire FGFLMC55GCA GAS RANGE
Frigidaire FGFLMC55GCB GAS RANGE
Frigidaire FGFLMC55GCC GAS RANGE
Frigidaire FGFLMC55GCE GAS RANGE
Frigidaire FGFLMC55GCF GAS RANGE
Frigidaire FGFLMC55GCG GAS RANGE
Frigidaire FGFLMC55GCH GAS RANGE
Frigidaire FGFLMC55GCJ GAS RANGE
Frigidaire FGFLMC55GCK GAS RANGE
Frigidaire FGFLZ87GCA GAS RANGE
Frigidaire FGFLZ87GCB GAS RANGE
Frigidaire FGFLZ87GCC GAS RANGE
Frigidaire FGFLZ87GCE GAS RANGE
Frigidaire FGFLZ87GCF GAS RANGE
Frigidaire FGFLZ87GCG GAS RANGE
Frigidaire FGFLZ87GCH GAS RANGE
Frigidaire FGFS36FUA GAS RANGE
Frigidaire FGFS36FUC GAS RANGE
Frigidaire FGFS36FUD GAS RANGE
Frigidaire FGFS36FWA Frigidaire/range
Frigidaire FGFS36FWB Frigidaire/range
Frigidaire FGFS36FWC GAS RANGE
Frigidaire FGFS36FWD GAS RANGE
Frigidaire FGFS36FWE GAS RANGE
Frigidaire FGFS36FWF GAS RANGE
Frigidaire FGFS36FWG GAS RANGE
Frigidaire FGFS36FWH GAS RANGE
Frigidaire FGFS36FWJ GAS RANGE
Frigidaire FGFS56FSA Frigidaire/range
Frigidaire FGFS68CJBA Frigidaire/gas Range
Frigidaire FGFS68CJSA Frigidaire/gas Range
Frigidaire FGFS68CJTA Frigidaire/gas Range
Frigidaire FGGC3045KBA COOKTOP
Frigidaire FGGC3045KBB COOKTOP
Frigidaire FGGC3045KSA COOKTOP
Frigidaire FGGC3045KSB COOKTOP
Frigidaire FGGC3045KWA COOKTOP
Frigidaire FGGC3045KWB COOKTOP
Frigidaire FGGC3065KBA COOKTOP
Frigidaire FGGC3065KBB COOKTOP
Frigidaire FGGC3065KSA COOKTOP
Frigidaire FGGC3065KSB COOKTOP
Frigidaire FGGC3065KWA COOKTOP
Frigidaire FGGC3065KWB COOKTOP
Frigidaire FGGC3645KBA COOKTOP
Frigidaire FGGC3645KBB COOKTOP
Frigidaire FGGC3645KSA COOKTOP
Frigidaire FGGC3645KSB COOKTOP
Frigidaire FGGC3645KWA COOKTOP
Frigidaire FGGC3645KWB COOKTOP
Frigidaire FGGC3665KBA COOKTOP
Frigidaire FGGC3665KBB COOKTOP
Frigidaire FGGC3665KSA COOKTOP
Frigidaire FGGC3665KSB COOKTOP
Frigidaire FGGC3665KWA COOKTOP
Frigidaire FGGC3665KWB COOKTOP
Frigidaire FGGF3031KBA GAS RANGE
Frigidaire FGGF3031KBB GAS RANGE
Frigidaire FGGF3031KBC GAS RANGE
Frigidaire FGGF3031KBD GAS RANGE
Frigidaire FGGF3031KBE GAS RANGE
Frigidaire FGGF3031KBF GAS RANGE
Frigidaire FGGF3031KBG GAS RANGE
Frigidaire FGGF3031KBH GAS RANGE
Frigidaire FGGF3031KBJ GAS RANGE
Frigidaire FGGF3031KQA GAS RANGE
Frigidaire FGGF3031KQB GAS RANGE
Frigidaire FGGF3031KQC GAS RANGE
Frigidaire FGGF3031KQD GAS RANGE
Frigidaire FGGF3031KQE GAS RANGE
Frigidaire FGGF3031KQF GAS RANGE
Frigidaire FGGF3031KQG GAS RANGE
Frigidaire FGGF3031KQH GAS RANGE
Frigidaire FGGF3031KQJ GAS RANGE
Frigidaire FGGF3031KWA GAS RANGE
Frigidaire FGGF3031KWB GAS RANGE
Frigidaire FGGF3031KWC GAS RANGE
Frigidaire FGGF3031KWD GAS RANGE
Frigidaire FGGF3031KWE GAS RANGE
Frigidaire FGGF3031KWF GAS RANGE
Frigidaire FGGF3031KWG GAS RANGE
Frigidaire FGGF3031KWH GAS RANGE
Frigidaire FGGF3031KWJ GAS RANGE
Frigidaire FGGF3032KBA GAS RANGE
Frigidaire FGGF3032KBB GAS RANGE
Frigidaire FGGF3032KBC GAS RANGE
Frigidaire FGGF3032KBD GAS RANGE
Frigidaire FGGF3032KBE GAS RANGE
Frigidaire FGGF3032KBF GAS RANGE
Frigidaire FGGF3032KBG GAS RANGE
Frigidaire FGGF3032KBH GAS RANGE
Frigidaire FGGF3032KBJ GAS RANGE
Frigidaire FGGF3032KWA GAS RANGE
Frigidaire FGGF3032KWB GAS RANGE
Frigidaire FGGF3032KWC GAS RANGE
Frigidaire FGGF3032KWD GAS RANGE
Frigidaire FGGF3032KWE GAS RANGE
Frigidaire FGGF3032KWF GAS RANGE
Frigidaire FGGF3032KWG GAS RANGE
Frigidaire FGGF3032KWH GAS RANGE
Frigidaire FGGF3032KWJ GAS RANGE
Frigidaire FGGF3041KFA GAS RANGE
Frigidaire FGGF3041KFB GAS RANGE
Frigidaire FGGF3041KFC GAS RANGE
Frigidaire FGGF3041KFD GAS RANGE
Frigidaire FGGF3041KFE GAS RANGE
Frigidaire FGGF3041KFF GAS RANGE
Frigidaire FGGF3041KFG GAS RANGE
Frigidaire FGGF3041KFH GAS RANGE
Frigidaire FGGF3041KFJ GAS RANGE
Frigidaire FGGF3041KFK GAS RANGE
Frigidaire FGGF3042KFA GAS RANGE
Frigidaire FGGF3042KFB GAS RANGE
Frigidaire FGGF3042KFC GAS RANGE
Frigidaire FGGF3042KFD GAS RANGE
Frigidaire FGGF3042KFE GAS RANGE
Frigidaire FGGF3042KFF GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gas Oven burner won't ignite dmargosh Oven Repair (including Ranges and Cooktops) 1 01-06-2013 05:14 PM
Oven Burner won't ignite Judy Niznak Oven Repair (including Ranges and Cooktops) 0 01-16-2010 09:11 AM
Pilot on-oven burner does not ignite dougmax Oven Repair (including Ranges and Cooktops) 0 10-22-2009 10:14 AM
Oven burner will not ignite RonnieT Oven Repair (including Ranges and Cooktops) 1 07-23-2008 08:57 AM
Oven Pilot lit, but burner will not ignite lsilvestri46 Oven Repair (including Ranges and Cooktops) 0 02-08-2008 03:09 PM
