Discuss
Replaced almost everything
 in
have a jenn-air model W30400W built in oven. So far, I have replaced the sensor, thermostat, control, and relay board
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Replaced almost everything
  #1 (permalink)
Old 02-27-2013, 12:57 PM
Junior Member
markgflanagan is on a distinguished road
Default Replaced almost everything
Brand: Jenn-Air   Age: More than 10 years
have a jenn-air model W30400W built in oven. So far, I have replaced the sensor, thermostat, control, and relay board at a total cost of around $550 and my oven still doesn't work (bake or broil). Elements are good. Only thing I can think is the wiring harness from the control to the relay board. Otherwise, I must have bought a defective part and have no idea which one it would be.
  #2 (permalink)
Old 02-28-2013, 03:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Have you checked the power at the unit?
The control board and fan will run on 120 volts but the elements require the full 240.
Note: It is not good enough to just measure each side of the line to Neutral, and get two 120 volts readings and then assume that you have the 240.
You must measure L1 to L2 and get 240 volts.
__________________
  #3 (permalink)
Old 02-28-2013, 05:47 AM
Junior Member
Default
Yes, I have 240V checked phase to phase from L1 to L2 where they attach to the relay board.
  #4 (permalink)
Old 03-01-2013, 02:29 AM
Senior Expert
APP Volunteer
Default
Next thing to check would be the hi-limit thermostat in the common L1 line to the elements.
Following is a link to a service manual (16010312 Jenn-Air Electric Wall Oven Service Manual). You will probably have to join the site to get the service manual, but joining is free.
http://appliancejunk.com/forums/inde...=view;down=414
__________________
  #5 (permalink)
Old 03-01-2013, 07:41 AM
Junior Member
Default
I'll see if this manual explains how to check the thermostat, I already replaced the thermostat along with the relay board, control, and sensor.
Thanks, Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Gas won't ignite, igniter replaced, coils replaced JTPaul Dryer Repair 3 12-03-2012 10:31 AM
Replaced ERC - Now What? txvike59 Oven Repair (including Ranges and Cooktops) 0 10-27-2011 07:26 PM
Whirlpool Qt Prtnr II, Replaced Htg Element Does the Control Panel Nd 2 B Replaced? DirtyDishes4Five Dishwasher Repair 1 10-26-2010 02:14 AM
Replaced most of it tried_it Dryer Repair 3 02-13-2009 04:18 AM
