| » Whirlpool Accubake Electric Range |
Model Number: 8113P680-60 Brand: Whirlpool Age: 1 - 5 years
Hello!
My first time on the forum, just wondering if the experts could help me diagnose / suggest solutions one of my problems The majority of the buttons on the control panel of my electric range suddenly does not work. More specifically, the stove top works fine, it's just the oven control panel. Clock still displays, and if I can press "Clock" to edit it (but none of the number buttons work). I can start "Broil", but the "Bake" button doesn't work. Really appreciate any help and response! Ads By Google Related Models |
I cannot find any info on the given model number.
Please check it. Find your model number - AppliancePartsPros.com
__________________
Sorry but I still cannot find any info on this unit.
Tried at AppliancePartsPros and the Whirlpool site. If the unit uses a separate control panel (keypad) and control board (timer/clock) you may want to try the following. Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. If the unit has the keypad and timer as one peice then it is probably the timer. You may also need an overlay as they are usually glued to the timer and can be difficult to get off/
__________________
| Display Modes | |
| Whirlpool Accubake Electric Range | RT White | Oven Repair (including Ranges and Cooktops) | 3 | 11-07-2012 11:45 AM |
| Whirlpool Accubake Electric Range | Baronesskai | Oven Repair (including Ranges and Cooktops) | 1 | 09-27-2012 02:43 PM |
| Whirlpool Accubake Electric Oven | CLR | Oven Repair (including Ranges and Cooktops) | 1 | 04-10-2010 03:33 PM |
| Whirlpool Electric Accubake Range | chinson | Oven Repair (including Ranges and Cooktops) | 0 | 12-26-2009 02:56 PM |
| Whirlpool Electric Accubake 465 range oven issue | surpriseaz44 | Oven Repair (including Ranges and Cooktops) | 0 | 01-26-2009 08:52 PM |
