Discuss
How to use self cleaning on Tappan oven
 in
I recently moved and am not sure how to use the self cleaning mode on this oven. I set the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » How to use self cleaning on Tappan oven
  #1 (permalink)
Old 02-04-2008, 06:01 PM
miley1028 miley1028 is offline
Junior Member
miley1028 is on a distinguished road
Default How to use self cleaning on Tappan oven
Model Number: teo356bfw3   Brand: Tappan   Age: 1 - 5 years
I recently moved and am not sure how to use the self cleaning mode on this oven. I set the dial to clean and lock the door. The clean light goes on but not the lock and it is not cleaning. Any ideas ??? I do not have the owners manual
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-05-2008, 02:10 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
You have to set the cleaning time on the clock too.
There are two small dials on the clock, one says "start" and another one says "stop".
The arrow on the "start" dial should show the same time which is shown on the clock.
Push and turn the knob on the "stop" dial to move the arrow for about three hours ahead of the clock time.
If the clock is broken, the self clean would not work.
Unfortunately the new clock is no longer available.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-05-2008, 05:36 PM
Junior Member
Default
did that but lock light still not on and cleaning not started. do i need to set the thermostat knob to a certain temp
  #4 (permalink)
Old 02-05-2008, 06:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the thermostat has the "clean" mark - it has to be turned on.
If it does not have a such mark - keep it "off".
__________________
  #5 (permalink)
Old 10-30-2008, 11:53 AM
lweigel lweigel is offline
Junior Member
lweigel is on a distinguished road
Question next step
I recently moved and have my first self-cleaning oven, naturally, without an instruction manual. When the clean cycle shuts down, and the door unlocks, (hate to sound totally stupid) but what do I do next? Do I spray anything on it, do I just wipe the inside, or should I have sprayed before setting the timer on cleaner? Help!
  #6 (permalink)
Old 10-30-2008, 11:56 AM
Junior Member
Question
Previously sent, but I must have slipped up somewhere. New (to me) self-cleaning in apartment. How to use, spray something? Just wipe? (shortened version)
  #7 (permalink)
Old 10-30-2008, 12:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You do not have to use any chemicals with a self clean oven. Wipe out any excessive grease before you run self clean and wipe out any ashes after. Remove all wire racks to prevent their discoloration.
__________________
  #8 (permalink)
Old Today, 05:08 AM
darabeam darabeam is offline
Junior Member
darabeam is on a distinguished road
Default What if I already started clean cycle and clock is broken?
Please help -- I have this same problem, and knew the clock was broken but didn't realize that would be a problem. I set clean cycle and it ran all night. Both lights (clean and lock) still on this morning, so I switched control knob to off, out of fear of fire hazard, and not knowing what else to do. Of course, it is still locked. Will it eventually cool and unlock, or do I have a huge problem?
Thanks!
Dara
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan Gas Oven Will Not Light Oscarshouse Oven Repair (including Ranges and Cooktops) 0 01-21-2008 04:36 PM
Tappan Oven not lighting TFitz Oven Repair (including Ranges and Cooktops) 2 01-16-2008 09:27 AM
Tappan Oven Chuck McCance Oven Repair (including Ranges and Cooktops) 2 11-20-2007 09:27 PM
self-cleaning oven got so hot when cleaning that it melted the surrounding cabinet do anne Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:30 PM
Tappan Wall Oven jake Oven Repair (including Ranges and Cooktops) 3 08-13-2007 11:53 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
