| » Bake element not working |
Model Number: ffflz287gcc Brand: Frigidaire Age: 5 - 10 years
The bake element stopped working. Unit displays on clock that it is pre- heating, but it is not. I tested the element for continuity and it appears okay. I changed out the Control board and it did not make any difference either. Broiler works and oven temp probe are working also. Even though the display looks like it is working could it be the problem? Thanks any helps would be greatly appreciated.
Ads By Google Related Models Last edited by msbee03 : 02-25-2013 at 12:38 PM. Reason: wrong model number should be feflz287gcc |
Sorry about that the correct model on this stove is feflz287gcc. That is what I get for typing this without wearing my glasses.
Still cannot find any info on it.
Are you sure that it has the 2 in it? I doubt it is te keypad as the display shows it is in preheat so it should be preheating. Check the wires from the element up to the control board.
__________________
| Display Modes | |
| bake element and broil element quit working | striperdaddy | Oven Repair (including Ranges and Cooktops) | 0 | 04-18-2010 11:12 AM |
| Replaced upper broil element, lower bake element. Elements still not working | bumdout | Oven Repair (including Ranges and Cooktops) | 1 | 11-25-2009 02:49 PM |
| Oven bake/broil not working after bake element replacement | J Justin | Oven Repair (including Ranges and Cooktops) | 1 | 11-05-2009 04:36 PM |
| Bake element not working | WOOFER95 | Oven Repair (including Ranges and Cooktops) | 0 | 08-07-2008 07:38 AM |
| Bake Element and BAKE cycle not working | jeffman | Oven Repair (including Ranges and Cooktops) | 1 | 08-04-2007 10:18 PM |
