| » Frigidaire F10 code-runaway temperature |
Model Number: GLEF379DQG Brand: Frigidaire Age: 5 - 10 years
Oven temperature takes off; stove shows F10 code and beeps. You can turn the oven off but when you restart it the same thing happens?
Worth repairing or time for a new one? How to troubleshoot? Ads By Google Related Models |
Hi.
First, check using the multimeter the temperature sensor's resistance. You can do it at the control board 15 pin plug between pins 12-13. At room temperature you should read about 1100ohm. Replace if it's off Part number: 316490001 If the sensor is good - replace the control board Part number: 316557205 You may need an overlay too Part number: 316419305 Here are the breakdown diagrams and Backguard parts for Frigidaire GLEF379DQG - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
The molex plug has no wires in positions 12, 14, or 15, unless I'm counting from the wrong end. |
Hi.
You are looking at the wrong end. Look careful at the end of the plug, they should be marked. Simon.
__________________
| Display Modes | |
| F10 Error Code; Runaway Temperature | Keith Hocky | Oven Repair (including Ranges and Cooktops) | 2 | 10-19-2010 06:00 AM |
| frigidaire fef366 oven seems like in runaway condition | rontcarb | Oven Repair (including Ranges and Cooktops) | 0 | 10-11-2010 03:47 PM |
| maytag oven slow baking plus runaway high temperature | russell harris | Oven Repair (including Ranges and Cooktops) | 2 | 02-13-2009 10:15 AM |
| bake temp runaway code on a kitchenaid oven | modemdog | Oven Repair (including Ranges and Cooktops) | 5 | 09-15-2008 01:53 PM |
| Oven Temperature Runaway | jimk | Oven Repair (including Ranges and Cooktops) | 1 | 12-09-2007 12:27 PM |
