GE Oven
Model Number: J HP 7oN OK2 Brand: GE Age: More than 10 years
Any input is apprecaited. Bake element broke/cracked in half in the oven. I replaced it, but it still will not heat up. The broiler works fine. I checked the wiring in the back that connect to the bake element. They look fine. Should I try replacing the oven control switch. It is a discontinued part, but I was able to find a replacement on line.
Thank you,
Jay
Ads By Google
Related Models
Reason: Mis information
