Discuss
GE downdraft vent won't raise & motor continues to run
 in
I turned off the unit using the selector switch and then attempted to lower it. After about a second the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE downdraft vent won't raise & motor continues to run
  #1 (permalink)
Old 02-20-2013, 01:00 PM
Junior Member
nickmo609 is on a distinguished road
Default GE downdraft vent won't raise & motor continues to run
Model Number: ZVB36SHSS   Brand: GE   Age: 1 - 5 years
I turned off the unit using the selector switch and then attempted to lower it. After about a second the gear seemed to disengage and the unit fell the remainder of thee way into it's hole. Now if I plug it in, the motor continues to run and won't raise. Do I need a new motor? Gear? Or is possible that the gear just needs to be manually re-engaged?
Ads By Google
Related Models
General Electric ZVB36WB2WW Electric range
General Electric ZVB36WB3WW Electric range
General Electric ZVB36WB4WW Electric range
General Electric ZVB36WH1WW Electric range
General Electric ZVC30L1SS Electric range
General Electric ZVC36L1SS Electric range
General Electric ZVC42L1SS Electric range
General Electric ZVC48L1SS Electric range
General Electric ZVC54L1SS Electric range
General Electric ZWVS1000SRA Wine vault
General Electric ZWVT1000SRA Wine vault
General Electric ZX24CTBSS Range accessory
General Electric ZX27CTACSS Range accessory
General Electric ZX27CTYSS Range accessory
General Electric ZX2LY2SS Gas range
General Electric ZX2LYSS Gas range
General Electric ZX2NY2SS Gas range
General Electric ZX2NYSS Gas range
General Electric ZX2YSS Gas range
General Electric ZX36CTACSS Range accessory
General Electric ZX36CTYSS Range accessory
General Electric ZX48CTACSS Range accessory
General Electric ZX48CTYSS Range accessory
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpool downdraft vent sorton1111 Oven Repair (including Ranges and Cooktops) 0 07-18-2012 06:07 AM
dacor cooktop vent will not raise jimgw Oven Repair (including Ranges and Cooktops) 0 12-29-2011 02:23 PM
GE telescoping downdraft won't raise pftrack Oven Repair (including Ranges and Cooktops) 0 10-20-2011 05:33 AM
GE downdraft vent system R Grubb Oven Repair (including Ranges and Cooktops) 4 08-27-2010 09:04 AM
Telescoping Downdraft Vent David Griffith Oven Repair (including Ranges and Cooktops) 0 04-03-2009 10:04 AM
