Discuss
oven lights, but does not remain lit
 in
I have a Bertazzoni model X365GGVX oven/stove. I have searched the forum and, though I've seen similar problems, I don't
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven lights, but does not remain lit
  #1 (permalink)
Old 02-19-2013, 03:35 PM
Junior Member
bobinca is on a distinguished road
Default oven lights, but does not remain lit
Model Number: Bertazzonni X365ggvx   Brand: -other-   Age: 5 - 10 years
I have a Bertazzoni model X365GGVX oven/stove. I have searched the forum and, though I've seen similar problems, I don't see exactly the same thing as I'm experiencing, so I'm posting this. Thanks in advance for any help you may be able to offer.
My gas oven uses an electrical ignitor/spark to ignite the gas, for the broiler and for the oven. The proper procedure is to (1) leave the door ajar, (2) turn the knob to start the gas flow (for either the broiler, top, or the oven, bottom), (3) depress the button to initiate the ignitor/spark, and (4) after the gas ignites, hold the ignitor/spark for 10 seconds. After this, you can release the ignitor/spark and the broiler or oven will remain lit.
Though a pain, this has always worked. Now, though, the oven portion will light this way but will not remain lit. The broiler will light and remain lit.
From this, I presume that the gas flow is fine, since the broiler works and the oven will also ignite fine and appears to have full gas flow. Also, the ignitor/spark is working for the broiler and oven too. But, the oven will not remain lit, whereas the broiler will.
The odd thing is that I discovered that if I first light the broiler and let it burn for 10 seconds or so, I can then successfully light the oven and it WILL remain lit. So, it CAN work, but it won't work if I try to light the oven first.
Ideas?
Ads By Google
Related Models
Crosley BES322ES1 BEAUMARK/ELECTRIC RANGE
Crosley BES322ES3 BEAUMARK/ELECTRIC RANGE
Crosley BES322ES6 BEAUMARK/RANGE
Crosley BES372ES1 BEAUMARK/ELECTRIC RANGE
Crosley BES374ES1 BEAUMARK/ELECTRIC RANGE
Crosley BES374ES2 BEAUMARK/ELECTRIC RANGE
Crosley BES374ES3 BEAUMARK/RANGE
Crosley BES374ES4 BEAUMARK/ELECTRIC RANGE
Crosley BES375ES1 BEAUMARK/ELECTRIC RANGE
Crosley BES375ES3 BEAUMARK/ELECTRIC RANGE
Crosley BES375ES4 BEAUMARK/RANGE
Crosley BES375ES5 BEAUMARK/ELECTRIC RANGE
Crosley BES384EB1 BEAUMARK/ELECTRIC RANGE
Crosley BES384EB2 BEAUMARK/RANGE
Crosley BES384EB3 BEAUMARK/ELECTRIC RANGE
Crosley BES384EB4 BEAUMARK/ELECTRIC RANGE
Crosley BES384EC1 BEAUMARK/ELECTRIC RANGE
Crosley BES384EC3 BEAUMARK/RANGE
Crosley BES384EC4 BEAUMARK/ELECTRIC RANGE
Crosley BES384ES1 BEAUMARK/ELECTRIC RANGE
Crosley BES384ES2 BEAUMARK/RANGE
Crosley BES384ES3 BEAUMARK/ELECTRIC RANGE
Crosley BES384ES4 BEAUMARK/ELECTRIC RANGE
Roper BES430WW0 Ranges, Electric*
Roper BES430WW1 Ranges, Electric*
Roper BES450WB0 Ranges, Electric*
Roper BES450WB1 Ranges, Electric*
Roper BES450WB2 Ranges, Electric*
Roper BES730WB0 Ranges, Electric*
Roper BES750WB0 Ranges, Electric*
Hardwick BEV7110 WALLOVEN- S/C ELE
Frigidaire BF18P2 Frg(v1) / 18 " Dishwasher
Frigidaire BF18PA2 Frg(v4) / 18 " Dishwasher
Frigidaire BF18PF3 Frg(v3) / 18 " Dishwasher
Frigidaire BF18PH2 Frg(v2) / 18 " Dishwasher
Frigidaire BF18PW2 Frg(v5) / 18 " Dishwasher
Whirlpool BFD200 DEHUMIDIFIER
Whirlpool BFD300 DEHUMIDIFIER
Whirlpool BFD400 DEHUMIDIFIER
Whirlpool BFD401 DEHUMIDIFIER
Whirlpool BFD500 DEHUMIDIFIER
Frigidaire BFEF320ES1 Frigidaire Canada/electric Range
Frigidaire BFEF320ES2 Frigidaire Canada/electric Range
Frigidaire BFEF323ES1 Frigidaire Canada/electric Range
Frigidaire BFEF323ES2 Frigidaire/range
Frigidaire BFEF323ES3 Frigidaire/range
Frigidaire BFEF374EB1 Frigidaire Canada/electric Range
Frigidaire BFEF374EB2 Frigidaire Canada/electric Range
Frigidaire BFEF374EB3 Frigidaire/range
Frigidaire BFEF374EB4 Frigidaire Canada/electric Range
Frigidaire BFEF374ES1 Frigidaire Canada/electric Range
Frigidaire BFEF374ES2 Frigidaire Canada/electric Range
Frigidaire BFEF374ES3 Frigidaire/range
Frigidaire BFEF374ES4 Frigidaire Canada/electric Range
Frigidaire BFEF374FC1 Frigidaire Canada/electric Range
Frigidaire BFEF374JIS1 ELECTRIC RANGE
Frigidaire BFES368EC1 Frigidaire Canada/electric Range
Frigidaire BFES368EC2 Frigidaire Canada/electric Range
Frigidaire BFES368EC3 Frigidaire/range
Frigidaire BFES368EC4 Frigidaire/range
Frigidaire BFES368EC5 Frigidaire Canada/electric Range
Frigidaire BFES368EC6 Frigidaire Canada/electric Range
Frigidaire BFES368EC7 ELECTRIC RANGE
Frigidaire BFES368ES1 Frigidaire/electric Range
Frigidaire BFES368ES2 Frigidaire Canada/electric Range
Frigidaire BFES368ES3 Frigidaire Canada/electric Range
Frigidaire BFES368ES4 Frigidaire Canada/electric Range
Frigidaire BFES368ES5 Frigidaire/range
Frigidaire BFES368ES6 FRIGIDAIRE/RANGE
Amana BFF105 REF - BOTTOM MOUNTS
Amana BFF105L REF - BOTTOM MOUNTS
Amana BFF125 REF - BOTTOM MOUNTS
Amana BFF125L REF - BOTTOM MOUNTS
Amana BFF98 REF - BOTTOM MOUNTS
Amana BFF98L REF - BOTTOM MOUNTS
Frigidaire BFFC05M2MW0 FREEZER
Amana BFFS105 REF - BOTTOM MOUNTS
Amana BFFS105L REF - BOTTOM MOUNTS
Amana BFFS125 REF - BOTTOM MOUNTS
Amana BFFS125L REF - BOTTOM MOUNTS
Amana BFFS98 REF - BOTTOM MOUNTS
Amana BFFS98L REF - BOTTOM MOUNTS
Frigidaire BFHS2611LM0 REFRIGERATOR
Frigidaire BFHS2611LM1 REFRIGERATOR
Frigidaire BFHS2611LM2 FRIGIDAIRE/REFRIGERATOR
Whirlpool BFR101 Air-conditioner/heat pump
Whirlpool BFR1011 Air-conditioner/heat pump
Amana BFR105 REF - BOTTOM MOUNTS
Amana BFR105L REF - BOTTOM MOUNTS
Whirlpool BFR121 Air-conditioner/heat pump
Whirlpool BFR183 HI EFFICIENCY 18,000 BTU/HR AIR CONDITIONER
Whirlpool BFR243 Air-conditioner/heat pump
Whirlpool BFR51 Air-conditioner/heat pump
Whirlpool BFR61 Air-conditioner/heat pump
Whirlpool BFR81 Air-conditioner/heat pump
Amana BFR95 REF - BOTTOM MOUNTS
Amana BFR95L REF - BOTTOM MOUNTS
Whirlpool BFRE123 Air-conditioner/heat pump
Whirlpool BFRE183 Air-conditioner/heat pump
Whirlpool BFRE81 Air-conditioner/heat pump
Whirlpool BFRH123 Air-conditioner/heat pump
Whirlpool BFRH183 Air-conditioner/heat pump
Whirlpool BFRH81 Air-conditioner/heat pump
Amana BG18VL REF - BOTTOM MOUNTS
Amana BG18VW REF - BOTTOM MOUNTS
Amana BG20T2L REF - BOTTOM MOUNTS
Amana BG20T2W REF - BOTTOM MOUNTS
Amana BG20TL REF - BOTTOM MOUNTS
Amana BG20TW REF - BOTTOM MOUNTS
Amana BG21V1C REF - BOTTOM MOUNTS
Amana BG21V1W REF - BOTTOM MOUNTS
Amana BG21VC REF - BOTTOM MOUNTS
Amana BG21VL REF - BOTTOM MOUNTS
Amana BG21VW REF - BOTTOM MOUNTS
  #2 (permalink)
Old 02-19-2013, 08:01 PM
Junior Member
Default
Some more info: though I'm able to start the oven using the method mentioned (light the broiler, turn it off, light the oven), I just discovered that the oven does not stay lit this way. It goes out after about 30 seconds. By contrast, the broiler will light and stay lit.
  #3 (permalink)
Old 02-20-2013, 04:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately we do not have access to any technical information for this product.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 02-20-2013, 11:52 PM
Junior Member
Default
Absent the specific technical info for this particular product, does anyone have any ideas as to what the issues might be? Thermocouple, for example? Something else? Does this problem (oven burner will not remain lit) typically result from the failure of some specific part?
  #5 (permalink)
Old 06-15-2013, 12:57 PM
Junior Member
Puulima is on a distinguished road
Default Same exact issue
@bobinca - I have the exact same issue you describe - including being able to light the broiler ok - and the oven lighting if the broiler is lit first - but then goes out 20 seconds later.
Did you have yours serviced - and/or discover what the issue was? Out started doing this last night - so can't call for service until Monday.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pilot can't remain dirtyhands Heating, Ventilation, and Air Conditioning (HVAC) 1 11-11-2011 05:06 PM
GE Gas Dryer will not remain running Scott270 Dryer Repair 0 11-11-2011 12:13 PM
Gas Range w electric pilot oven won't remain lit mzmccoy1 Oven Repair (including Ranges and Cooktops) 0 08-15-2009 06:54 PM
