| » Jenn-Air convection oven not heating |
Model Number: 8114P955-60 Brand: Jenn-Air Age: 5 - 10 years
Over the past 6 weeks our Jenn-Air convection oven has not been heating up. We have used the self-clean option in the past (maybe 5xs total in the past 10 yrs.). About a month ago it wouldn't heat up at all so we turned the power off, then back on and that seemed to jump start it. But today I tried to bake something at 350F. It took an hour to get the temp up to just 346F, and to get it to go up to that temp I had to program the temp for 450F.
Do you think this sounds like we need to replace the heating element? Many thanks in advance for your advice, RBR Ads By Google Related Models |
Hi.
It doesn't look like correct model number. Please check again. Does the bake ielement gets red hot? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 02-19-2013 at 11:57 AM. |
Dear Simon,
Thank you for responding. Sorry, the correct model number: JMW9530DAB Excuse my totaly ignorance on the terminology (ha, ha), but is the bake ignitor the apparatus behind the circular honeycomb-like plate at the back of the oven? If so, then no, it does not appear to get red hot like it used to, sadly. Does that sound like a bake ignitor issue? The broil coils still get red hot, but not the other apparatus. Thanks, ~RBR Last edited by rbr : 02-19-2013 at 11:52 AM. |
Hi.
Sorry, made a mistake without the model number it's the element not the ignitor. My question is: does the bake element and convection element get hot? The convection element comes as an assembly with the fan motor. If only convection bake doesn't work, you need to check if there is 240VAC coming to it or sometimes just visually you can determine if it's bad. To get access to the convection element you do need to remove the cover (honeycomb). Part number: W10206587 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 02-19-2013 at 12:13 PM. |
Simon,
Thank you for the great information! I have an update and wondered if it would change the advice and/or the part that we need to order. I generally only bake in convection mode. Today, just for grins, I choose the regular bake cycle and my oven heats up beautifully in the "bake" mode. The heating element behind the honeycomb cover @ the back of the oven glows red. Apparently, it is only convection mode that isn't working? Does this change the part number we need to order? Many thanks in advance for your wonderful tips! You are appreciated. ~RBR |
Hi.
If you read my previous post you should notice that I didn't tell you to replace the convection element, I suggested you to test it first. Another question: does the convection fan runs? OK, if you are absolutely sure the convection element gets red hot and convection fan runs - you need to replace control board Part number: 74009716 Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Apologizing before I ask what is probably a goofy question, but:
**How do I know if the convection fan is running? ** Is that what I hear when I turn the oven on? Or can I test the fan? Thank you in advance (again) for all of your help! Last edited by rbr : 02-25-2013 at 07:37 PM. |
Hi.
The convection fan blows air inside the oven when the oven is on.When you open the door it's stops. Simon.
__________________
| Display Modes | |
| Jenn-Air Convection Oven Heating Issue | llmb95 | Oven Repair (including Ranges and Cooktops) | 3 | 02-19-2013 10:07 AM |
| Jenn-Air Radiant Range with Convection Oven | Dee | Oven Repair (including Ranges and Cooktops) | 1 | 10-17-2011 03:08 PM |
| Jenn-Air Dual Convection Oven | PHYLLIS695 | Oven Repair (including Ranges and Cooktops) | 0 | 11-03-2010 05:09 AM |
| Jenn-Air Convection Oven | BillRoss | Oven Repair (including Ranges and Cooktops) | 1 | 12-18-2008 09:35 AM |
| jenn air convection oven | bushbg | Oven Repair (including Ranges and Cooktops) | 0 | 05-26-2008 10:20 AM |
