| » GE oven won't heat past 170 or so |
Model Number: JBP66BY5AD Brand: GE Age: More than 10 years
Oven won't heat past about 170 or so. Broiler works fine. Replaced oven baking element...same problem. I can hear the thermostat clicking but it never achieves the higher temperatures.
Help!!! Ads By Google Related Models |
Hi.
Please check the oven sensor resistance. At room temperature you should have about 1100ohm and if it checks OK - replace the control board. The sensor Part number: WB23T10002 The control board Part number: WB27X10311 Here are the breakdown diagrams and Control Panel & Cooktop parts for GE JBP66BY5AD - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Oven won't heat past 300 | MollyH | Oven Repair (including Ranges and Cooktops) | 0 | 11-15-2012 03:39 PM |
| Oven will not heat past 250 | geekfather | Oven Repair (including Ranges and Cooktops) | 3 | 04-13-2012 03:55 AM |
| Oven won't heat past 200 | esamuels | Oven Repair (including Ranges and Cooktops) | 0 | 03-28-2010 06:15 PM |
| oven will not heat past 300 | rangerkim | Oven Repair (including Ranges and Cooktops) | 0 | 03-01-2009 04:15 PM |
| Oven won't heat past 350 degrees | tlpyle | Oven Repair (including Ranges and Cooktops) | 1 | 11-18-2008 12:41 PM |
