| » Maytag oven ignitor not working |
Model Number: MGR5775QDQ Brand: Maytag Age: 1 - 5 years
I replaced the oven ignitor a few weeks ago; but neglected to push the ignitor lead connectors all the way through the back of the oven. The oven was working fine after ignitor replacement; until we ran a self-cleaning cycle. The high temps of the cleaning cycle melted the ignitor connector leads, after which the oven stopped working again.
Bought a new ignitor and installed it; but it's not glowing at all in bake mode. Checked voltage between between lead coming down from the control panel in bake mode & chassis ground, and it reads 120V - but the voltage between the two ignitor leads (the one coming down from the control panel & the one coming up from the gas valve) is only a few volts. I assume this voltage should be 120V as well? Could the gas valve have shorted out; or what could have happened when the original ignitor leads melted and shorted out? Thanks, - Gary Ads By Google Related Models |
Hi, Gary.
If you have 120VAC from Yellow to the ground, check the safety gas valve for continuity (Y to WH) with one wire off. The short created by high temperature "killed" the gas valve's coil. Replace the valve kit: Part number: 12002604 Here are the breakdown diagrams and 05-Gas Controls parts for Maytag MGR5775QDQ - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 02-18-2013 at 01:12 PM. |
| Display Modes | |
| maytag oven ignitor wiring | P5bdkw | Oven Repair (including Ranges and Cooktops) | 2 | 09-12-2011 11:37 AM |
| Burner Not Working, Ignitor Is Working Ok | jimzun | Dryer Repair | 0 | 06-22-2010 06:14 PM |
| cooktop,oven ignitor not working | vanrodd | Oven Repair (including Ranges and Cooktops) | 0 | 07-30-2009 06:56 PM |
| Maytag Oven Ignitor repair | ASJDAD | Oven Repair (including Ranges and Cooktops) | 1 | 11-17-2008 05:48 PM |
| Oven not working -- ignitor? | Patsy | Oven Repair (including Ranges and Cooktops) | 0 | 11-23-2007 10:19 AM |
