Discuss
GE oven burner valve leaking...which part does it need?
 in
I smelled gas when the oven/burners were off. PG&E said it is a oven burner valve leaking...which part do I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE oven burner valve leaking...which part does it need?
  #1 (permalink)
Old 02-13-2013, 03:11 PM
Junior Member
aprilsbrit is on a distinguished road
Default GE oven burner valve leaking...which part does it need?
Model Number: JGBS06eriwh   Brand: GE   Age: More than 10 years
I smelled gas when the oven/burners were off. PG&E said it is a oven burner valve leaking...which part do I need? Is it the safety valve? Please reply ASAP, I need my oven. Thank you. April
Related Models
General Electric JGBS06ES1 Gas range
General Electric JGBS06EV1AD Gas range
General Electric JGBS06EV1WH Gas range
General Electric JGBS06PPH1CT Gas range
General Electric JGBS06PPH1WH Gas range
General Electric JGBS06PPH2CT Gas range
General Electric JGBS06PPH2WH Gas range
General Electric JGBS06PPM1CT GAS RANGE
General Electric JGBS06PPM1WH GAS RANGE
General Electric JGBS06PPM2CT GAS RANGE
General Electric JGBS06PPM2WH GAS RANGE
General Electric JGBS06PPM3CT GAS RANGE
General Electric JGBS06PPM3WH GAS RANGE
General Electric JGBS06PPM5CT GAS RANGE
General Electric JGBS06PPM5WH GAS RANGE
General Electric JGBS06PV1AD Gas range
General Electric JGBS06PV1WH Gas range
General Electric JGBS07DEM1BB GAS RANGE
General Electric JGBS07DEM1CC GAS RANGE
General Electric JGBS07DEM1WW GAS RANGE
General Electric JGBS07DEM2BB GAS RANGE
General Electric JGBS07DEM2CC GAS RANGE
General Electric JGBS07DEM2WW GAS RANGE
General Electric JGBS07DEM3BB GAS RANGE
General Electric JGBS07DEM3CC GAS RANGE
General Electric JGBS07DEM3WW GAS RANGE
General Electric JGBS07DEM4BB GAS RANGE
General Electric JGBS07DEM4CC GAS RANGE
General Electric JGBS07DEM4WW GAS RANGE
General Electric JGBS07DET1BB GAS RANGE
General Electric JGBS07DET1CC GAS RANGE
General Electric JGBS07DET1WW GAS RANGE
General Electric JGBS07EV1WW Gas range
General Electric JGBS07EV2WW Gas range
General Electric JGBS07EV3WW Gas range
General Electric JGBS07PEA1WW Gas range
General Electric JGBS07PEA2WW Gas range
General Electric JGBS07PEA3WW Gas range
General Electric JGBS07PEA4WW Gas range
General Electric JGBS07PEA5WW Gas range
General Electric JGBS07PEA6WW Gas range
General Electric JGBS07PEA7WW Gas range
General Electric JGBS07PEH1BB Gas range
General Electric JGBS07PEH1CC Gas range
General Electric JGBS07PEH1WW Gas range
General Electric JGBS07PEH2BB Gas range
General Electric JGBS07PEH2CC Gas range
General Electric JGBS07PEH2WW Gas range
General Electric JGBS07PEM1BB GAS RANGE
General Electric JGBS07PEM1CC GAS RANGE
General Electric JGBS07PEM1WW GAS RANGE
General Electric JGBS07PEW1WW Gas range
General Electric JGBS07PEW2WW Gas range
General Electric JGBS07SEP1SA GAS RANGE
General Electric JGBS07SET1SA GAS RANGE
General Electric JGBS09PEF1WW Gas range
General Electric JGBS09PEH1WW Gas range
General Electric JGBS09PEH2WW Gas range
General Electric JGBS09PEH3WW Gas range
General Electric JGBS09PEH4WW Gas range
General Electric JGBS09PEH5WW Gas range
General Electric JGBS10BEF1BB Gas range
General Electric JGBS10BEH1BB Gas range
General Electric JGBS10BEH2BB Gas range
General Electric JGBS10BEH3BB Gas range
General Electric JGBS10BEH4BB Gas range
General Electric JGBS10BEH5BB Gas range
General Electric JGBS10CEF1CC Gas range
General Electric JGBS10CEH1CC Gas range
General Electric JGBS10CEH2CC Gas range
General Electric JGBS10CEH3CC Gas range
General Electric JGBS10CEH4CC Gas range
General Electric JGBS10CEH5CC Gas range
General Electric JGBS10WEF1WW Gas range
General Electric JGBS10WEH1WW Gas range
General Electric JGBS10WEH2WW Gas range
General Electric JGBS10WEH3WW Gas range
General Electric JGBS10WEH4WW Gas range
General Electric JGBS10WEH5WW Gas range
General Electric JGBS12GEN1 Gas range
General Electric JGBS12GEN2 Gas range
General Electric JGBS12GER1 Gas range
General Electric JGBS12GER2 Gas range
General Electric JGBS12GER3 Gas range
General Electric JGBS12GER4 Gas range
General Electric JGBS12GER5 Gas range
General Electric JGBS14GES1 Gas range
General Electric JGBS14GES2 Gas range
General Electric JGBS15EK1 Gas range
General Electric JGBS15EK3 Gas range
General Electric JGBS15EK7 Gas range
General Electric JGBS15EK8 Gas range
General Electric JGBS15GEK1 Gas range
General Electric JGBS15GEK3 Gas range
General Electric JGBS15GEK5 Gas range
General Electric JGBS15GEK6 Gas range
General Electric JGBS15GEK7 Gas range
General Electric JGBS15GEN1 Gas range
General Electric JGBS15GEN2 Gas range
General Electric JGBS15GER1 Gas range
General Electric JGBS15GER2 Gas range
General Electric JGBS15GER3 Gas range
General Electric JGBS15GER4 Gas range
General Electric JGBS15GER5 Gas range
General Electric JGBS15GER6 Gas range
General Electric JGBS15GER7 Gas range
General Electric JGBS15GPK1 Electric range
General Electric JGBS15GPK3 Gas range
General Electric JGBS15PEA1AD Gas range
General Electric JGBS15PEA1WH Gas range
General Electric JGBS15PEA2AD Gas range
General Electric JGBS15PEA2WH Gas range
General Electric JGBS15PEA3AD Gas range
General Electric JGBS15PEA3WH Gas range
General Electric JGBS15PEW1AD Gas range
General Electric JGBS15PEW1WH Gas range
General Electric JGBS15PK1 Gas range
General Electric JGBS15PK3 Gas range
General Electric JGBS16EH1 Electric range
General Electric JGBS16EH2 Gas range
  #2 (permalink)
Old 02-14-2013, 04:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi April,
You are on the right track. The only gas valve in the oven is the gas safety valve.
- The gas safety valve Part number: WB19K13
Here are the breakdown diagrams and Parts for GE JGBS06ER1 Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Changing the Burner Valve on GE Oven pilot718 Oven Repair (including Ranges and Cooktops) 0 07-29-2011 08:13 PM
Water Valve leaking part # AP2071735 jitters Refrigerator & Freezer Repair 0 02-11-2011 09:27 AM
GE Gas Oven - Igniter, Burner or Valve? PatrickMiami Oven Repair (including Ranges and Cooktops) 0 08-08-2010 08:03 AM
Need Check Valve for Part 560 Body Valve mjt Dishwasher Repair 0 08-31-2009 07:08 AM
Need part name for sticky oven valve/cellanoid jelmerick Oven Repair (including Ranges and Cooktops) 1 12-12-2008 02:23 PM
