| » Top oven doesn't get to selected temp |
Model Number: SC302TB Brand: Thermador Age: More than 10 years
The upper oven doesn't reach the temp selected. I notice that the element doesn't get bright red as it used to.
The other elements, broiler and convection and the lower oven elements, still get bright red. I tried to remove lower element, but it doesn't want to pull out more than 2 inches. Do you have to remove the convection fan assembly, to reach the connections so you can replace the element? I assume that the element is bad, how do you test it to be sure? Thanks for any help. Steve Ads By Google Related Models |
| Display Modes | |
| Oven won't heat up to selected temperature | Lunchbag | Oven Repair (including Ranges and Cooktops) | 0 | 12-22-2011 04:27 PM |
| oven doesn't heat to selected temp. | jimsmithbc | Oven Repair (including Ranges and Cooktops) | 1 | 11-02-2011 03:05 AM |
| F2 Error; Broiler comes on when oven is selected; oven doesnt come on at all | baychamp21ft | Oven Repair (including Ranges and Cooktops) | 4 | 11-22-2010 06:16 PM |
| oven temp selector and temp in oven varies significantly | larry68417 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2010 07:02 PM |
| Whirlpool Oven Temperature is Lower than Selected on Control Panel | Carol B | Oven Repair (including Ranges and Cooktops) | 1 | 11-07-2008 07:14 PM |
