| » Oven and Broil |
Model Number: 79078653601 Brand: Kenmore Age: 5 - 10 years
I have Kenmore rang suddenly 2 days ago both ignitor is glowing but no heat , now I'm confused , can be both ignitors became weak in the same time , or the safety valve ?The top burner is working .
Hi.
To check for sure if that is both ignitors or the gas valve you need to check the amps draw using the amp meter. The normal reading should be 3.2amp or more. If it's less then that replace both ignitors, if not - replace the gas valve. The bake ignitor Part number: 316489401 The broil Part number: 316489400 The gas valve Part number: 316404901 Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 02-12-2013 at 12:24 PM. |
| Display Modes | |
| Frigidaire Double Wall Oven Upper No Broil Lower No Oven | Jim Gaspar | Oven Repair (including Ranges and Cooktops) | 0 | 10-14-2012 12:50 PM |
| Oven won't bake or broil | ConnerNA | Oven Repair (including Ranges and Cooktops) | 2 | 10-12-2012 05:27 PM |
| oven broil | markrivera | Oven Repair (including Ranges and Cooktops) | 1 | 02-09-2011 03:45 AM |
| Gas oven-No Bake No Broil | dennis728 | Oven Repair (including Ranges and Cooktops) | 0 | 03-24-2010 08:15 AM |
| Gas Oven & Broil does not work... | zuraulevic | Oven Repair (including Ranges and Cooktops) | 0 | 11-30-2007 09:19 PM |
