Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven and Broil (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/517772-oven-broil.html)
Emil4 02-11-2013 06:00 PM
Oven and Broil
I have Kenmore rang suddenly 2 days ago both ignitor is glowing but no heat , now I'm confused , can be both ignitors became weak in the same time , or the safety valve ?The top burner is working .
Simon / APP Team 02-12-2013 12:13 PM
Hi.
To check for sure if that is both ignitors or the gas valve you need to check the amps draw using the amp meter. The normal reading should be 3.2amp or more. If it's less then that replace both ignitors, if not - replace the gas valve.
The bake ignitor Part number: 316489401
The broil Part number: 316489400
The gas valve Part number: 316404901
Post the results.
Simon.
