Discuss
Whirlpool double oven not heating after self cleaning
 in
I've read similar posts to my problem but want to verify I have the same problem and can be fixed
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool double oven not heating after self cleaning
  #1 (permalink)
Old 02-11-2013, 03:39 PM
Junior Member
Kristam is on a distinguished road
Default Whirlpool double oven not heating after self cleaning
Model Number: RBD305PDB812   Brand: Whirlpool   Age: 5 - 10 years
I've read similar posts to my problem but want to verify I have the same problem and can be fixed the same way. My oven worked fine yesterday morning and then I decided to clean the upper oven for the first time yesterday using the "self clean" function. About 2hrs into the cleaning cycle I heard a loud popping noise, the oven continued the cleaning process, completed the cycle and did a complete cool down and shut off. The inside is like new but now the upper and lower ovens do not heat. The control panel is operating normally, it sounds like the oven is heating but its not. Looking at prior posts, do we just need to replace the thermal fuse? If so, what are the step by step instructions on doing this, where is the fuse located and can this be done by us or do we need a professional come out? Please also confirm part # that is needed. Thank you for your help!
Ads By Google
Related Models
Whirlpool RBD305PDB9 ELECTRIC OVEN
Whirlpool RBD305PDQ1 ELECTRIC OVEN
Whirlpool RBD305PDQ10 ELECTRIC OVEN
Whirlpool RBD305PDQ11 ELECTRIC OVEN
Whirlpool RBD305PDQ12 ELECTRIC OVEN
Whirlpool RBD305PDQ13 ELECTRIC OVEN
Whirlpool RBD305PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDQ2 ELECTRIC OVEN
Whirlpool RBD305PDQ3 ELECTRIC OVEN
Whirlpool RBD305PDQ4 ELECTRIC OVEN
Whirlpool RBD305PDQ6 ELECTRIC OVEN
Whirlpool RBD305PDQ7 ELECTRIC OVEN
Whirlpool RBD305PDQ8 ELECTRIC OVEN
Whirlpool RBD305PDQ9 ELECTRIC OVEN
Whirlpool RBD305PDS12 ELECTRIC OVEN
Whirlpool RBD305PDS14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDS15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT11 ELECTRIC OVEN
Whirlpool RBD305PDT12 ELECTRIC OVEN
Whirlpool RBD305PDT13 ELECTRIC OVEN
Whirlpool RBD305PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT00 24" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PRT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD305PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT00 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER
Whirlpool RBD305PVT02 30" BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF
Whirlpool RBD305PVT03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB1 Built-In Oven, Electric
Whirlpool RBD306PDB10 OVEN
Whirlpool RBD306PDB11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB12 OVEN
Whirlpool RBD306PDB13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDB14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDB2 Built-In Oven, Electric
Whirlpool RBD306PDB4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDB7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDB8 ELECTRIC WALL OVEN
Whirlpool RBD306PDB9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ1 Built-In Oven, Electric
Whirlpool RBD306PDQ10 OVEN
Whirlpool RBD306PDQ11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ12 OVEN
Whirlpool RBD306PDQ13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDQ14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDQ2 Built-In Oven, Electric
Whirlpool RBD306PDQ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDQ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDQ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDQ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDT11 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT12 OVEN
Whirlpool RBD306PDT13 BUILT-IN OVEN, ELECTRIC
Whirlpool RBD306PDT14 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDT15 30" BUILT-IN ELECTRIC DOUBLE OVEN SELF-CLEAN UPPER AND LOWER OVENS
Whirlpool RBD306PDZ1 30" BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ10 OVEN
Whirlpool RBD306PDZ2 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ4 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ6 30" ELECTRIC DOUBLE OVEN
Whirlpool RBD306PDZ7 BUILT-IN ELECTRIC OVEN
Whirlpool RBD306PDZ8 ELECTRIC WALL OVEN
Whirlpool RBD306PDZ9 BUILT-IN ELECTRIC OVEN
Whirlpool RBD307PDB1 ELECTRIC OVEN
Whirlpool RBD307PDB2 ELECTRIC OVEN
Whirlpool RBD307PDQ1 ELECTRIC OVEN
Whirlpool RBD307PDQ2 ELECTRIC OVEN
Whirlpool RBD307PDQ4 ELECTRIC OVEN
Whirlpool RBD307PVB00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVB02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVB03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVQ00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVQ02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVQ03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Whirlpool RBD307PVS00 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEAN
Whirlpool RBD307PVS02 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION/SELF-CLEA
Whirlpool RBD307PVS03 30" BUILT-IN ELECTRIC DOUBLE OVEN
Maytag RBE170PA REF - TOP MOUNT
Maytag RBE170PW REF - TOP MOUNT
Maytag RBE170TA REF - TOP MOUNT
Maytag RBE170TM REF - TOP MOUNT
Maytag RBE170TV REF - TOP MOUNT
Maytag RBE170TW REF - TOP MOUNT
Maytag RBE17KA-0A REF - TOP MOUNT
Maytag RBE17KN-0A REF - TOP MOUNT
Maytag RBE193PA REF - TOP MOUNT
Maytag RBE193PW REF - TOP MOUNT
Maytag RBE193TA REF - TOP MOUNT
Maytag RBE193TM REF - TOP MOUNT
Maytag RBE193TV REF - TOP MOUNT
Maytag RBE193TW REF - TOP MOUNT
Maytag RBE19KA-3A REF - TOP MOUNT
Maytag RBE19KN-3A REF - TOP MOUNT
Maytag RBE19KY-3A REF - TOP MOUNT
Maytag RBE214AFM REF - TOP MOUNT
Maytag RBE214AFV REF - TOP MOUNT
Maytag RBE214RFA REF - TOP MOUNT
Maytag RBE214RFV REF - TOP MOUNT
Maytag RBE214TFA REF - TOP MOUNT
Maytag RBE214TFM REF - TOP MOUNT
Maytag RBE214TFV REF - TOP MOUNT
Maytag RBE21KA4AF REF - TOP MOUNT
  #2 (permalink)
Old 02-12-2013, 03:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Kristam View Post
...do we just need to replace the thermal fuse?...
Hello Kristam,
This question is inaccurate. It might be one of a possible cause of the problem but you have to run troubleshooting in order to determine exact cause of it. Especially because the lower oven does not have self clean and the fuse for the lower oven controls only the Broil circuit.
You can check the ovens shut down thermal fuses from the front of the oven. If any of them or both should be replaced then you will need to remove the oven completely from the cabinet and remove the rear cover..
Open the control panel (use first 6 steps from the attached instruction).
Check for 240 VAC between the Red and the Black wires at the terminal block. Check for 120 VAC between the Red & the White wires and the Black & the White wires at the terminal block. If any of the readings is incorrect, there is something wrong with the circuit breakers.
For the upper oven check for continuity between the wires connected to the P18-4 (red) or the P18-1 (red) terminals at the control board and the Red wire at the terminal block. The fuse is bad if it shows open circuit.
For the lower oven check for continuity between the wires connected to the P26-2 (or) terminal at the control board and the Red wire at the terminal block. The fuse is bad if it shows open circuit.
If there is nothing wrong with incoming voltage and the fuses then the problem is a bad control board. Unfortunately this part is no longer available.
- The upper oven shut down thermal fuse Part number: 9759243
- The lower oven shut down thermal fuse Part number: 4451354
Here are the breakdown diagrams and Parts for Whirlpool RBD305PDB8 Wall Oven - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gold Double Oven Not Working after self cleaning FixIt Herself Oven Repair (including Ranges and Cooktops) 0 01-13-2013 07:56 PM
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd sillyshopper Oven Repair (including Ranges and Cooktops) 6 02-12-2012 12:33 PM
whirlpool double oven died upon self cleaning momsmiles Oven Repair (including Ranges and Cooktops) 0 11-28-2010 09:34 AM
Whirlpool electric double oven not heating chikki28 Oven Repair (including Ranges and Cooktops) 0 10-13-2009 12:05 PM
Whirlpool Double Oven Turns Off Before Heating BlazeMiller Oven Repair (including Ranges and Cooktops) 5 06-22-2009 01:48 PM
