| » How to go about fixing my '79 Caloric range |
Model Number: Don't know Brand: Caloric Age: More than 10 years
The upper oven on my dual oven Caloric electric range has died. The range came new when the house was new in '79. The upper oven failed once roughly twenty years ago and was repaired by a technician. I don't know what he replaced, but in the process he broke two of the three clock dial shafts and three or more of the plastic knobs on the control panel at the upper left. A good job! I don't want to have to pay someone else for more of the same and so I'm trying to find out how to tackle this myself (besides, money's tight these days).
The symptom is I turn on the upper oven and the panel lamp comes on, but the oven element doesn't heat. With the breaker off, I checked continuity through the selector/thermostat switch and it appears OK (temporarily disconnected the wires, except for one that appears to be a temperature probe that passes below the oven door and up the right side, it isn't removable). So perhaps the lower element has failed (I never broil)? Or could there be something else causing the problem? Oh, yes -- if I turn the switch all the way to broil, the upper element doesn't heat either. I'm attaching photos of the range and hope they'll help (looked for a label but didn't spot one). Yeah, it could do with more cleaning. The four rocker switches below the panel are left to right: Timed/Upper/Manual, Upper Oven Lamp, Burner Deck Lamp, Timed/Lower/Manual. Here's hoping -- Trevor Range_2.jpg Photo by TrevorSt | Photobucket Range_3.jpg Photo by TrevorSt | Photobucket Range_1.jpg Photo by TrevorSt | Photobucket Range_4.jpg Photo by TrevorSt | Photobucket Ads By Google Related Models Last edited by TrevorS : 02-06-2013 at 06:25 PM. |
Hi Trevor,
There are two knobs in the upper portion of the clock. One of them should be pushed in while the other one should be popped out. You have to play with them. In order to pop it out you have to turn the dial to the 0 position. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Gene,
I actually don't use the timer function (the only user), but I just checked them and both the upper shafts are at zero and re-extend when I push and release them (left shaft STOP, right START). They only stay in if rotated past the zero point (pointer straight up). Also, the leftmost and rightmost rocker switches are both set to "Manual", not "Timed". Thanks -- Trevor Last edited by TrevorS : 02-07-2013 at 10:49 PM. |
Check the Bake heating element for continuity. Check the wires connected to the heating element.
__________________
Are you sure you can not just pull out the heating element from inside of the oven?
__________________
Sure enough, two Phillips screws and it pulls out. It tests open, and naturally, the rear connector pulled back through the hole following disconnection and so I have to re-feed it. Looks like I need to find a new lower element. I suppose the most likely explanation for no broil is a bad upper element -- have to see how to remove it.
Thanks -- Trevor Last edited by TrevorS : 02-09-2013 at 07:03 PM. |
Quote:
Range_5.jpg Photo by TrevorSt | Photobucket Range_6.jpg Photo by TrevorSt | Photobucket Range_7.jpg Photo by TrevorSt | Photobucket Dimensions are approx 4" element center-to-center deep by 16-7/8" from screw-mount tabs to right element center. The imprinted info on the top left of the element as best I can make out is "8459 (solder blobs and blank space) RP791 1500W 240V plus there may be a single numeral perhaps 6 or 8 a little further down. The first four characters are shown in the last photo above, the "R" of the second group is a best guess. If anyone can point me to a specific replacement element, that would be really great! I'd also appreciate a hint on how the upper (broil) element is removed. I don't see any fasteners on the left side of the oven and pulling towards the right doesn't seem to accomplish anything. I did notice its terminals behind the control panel are the same style as the lower element. Range_8.jpg Photo by TrevorSt | Photobucket Thanks and continuing to hope/hunt -- Trevor PS. Although it would be nice if I can locate an exact replacement, I'm perfectly willing to install an element that is merely close enough to do the job. If I have to modify the terminations or whatever, that's fine. As long as any mods are reasonably doable. PPS. Also, if anyone can identify either the exact Caloric Model (1979) or range of similar models from my photos, that would also be great. Last edited by TrevorS : 02-10-2013 at 04:39 PM. |
The part number RP791 crossed over to the Part number: CH5870
Check for the upper element fasteners behind the control panel. Gene.
__________________
Thanks very much Gene! Hunted around for a more helpful photo but nada, so took the plunge -- it works out or it doesn't. Whatever I receive, I'll report on it including a photo. My fingers are crossed!
Now, back to removal of the upper element. Hmm, think I'll heat some pasta first Thanks again -- Trevor Last edited by TrevorS : 02-11-2013 at 02:32 PM. |
| Display Modes | |
| Caloric gas range | 1whitbeck | Oven Repair (including Ranges and Cooktops) | 1 | 04-23-2012 05:05 PM |
| Fixing Lamp Switch on GE Range Hood | meeko | Oven Repair (including Ranges and Cooktops) | 0 | 10-26-2010 02:53 PM |
| GE Range Hood Fixing Broken SWITCH Electrical | rajkrishusa | Oven Repair (including Ranges and Cooktops) | 2 | 10-09-2009 05:48 PM |
| Caloric Gas Range | alansymss | Oven Repair (including Ranges and Cooktops) | 1 | 06-06-2009 03:02 PM |
| Caloric range | karl d Scheumann | Oven Repair (including Ranges and Cooktops) | 2 | 07-14-2008 01:22 PM |
