| » inside element on triple burner issue |
Model Number: MER6775BAF Brand: Maytag Age: 5 - 10 years
Five burner flat stove top. It popped the breaker yesterday, today it works fine, BUT the inside element on the front right three burner ALWAYS comes on no matter what other burner you turn on!! Stove does not effect it, but if any other burner is turned on, the inside elelment on the tripple burner always comes on. Any ideas where to start??
Thanks, Dan Ads By Google Related Models |
Hi Dan,
Remove the cooktop and the rear control panel cover. Check for continuity all infinite switches, the wires and the heating element for the triple burner. Post the results. Here are the breakdown diagrams and Parts for Maytag MER6775BAF Range - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
Thanks for the response. I will try tha and let you know what I find. Thanks, Dan |
The Infinite switch that controls the triple burner was the culprit. I pulled it out and it had a pretty good burn mark on it, so I suspected it before I checked continuity. The switch itself does NOT have H1 and H2 marked specifically, but the diagram you sent does, and with the switch OFF, H1 and H2 had continuity. $50 later for the new switch, and no more ghost burner!!
Thanks for the information. |
You are welcome Dan. I'm glad it's up and running. Good job!
__________________
| Display Modes | |
| Maytag 800 single burner in triple burner does not work | jmince101 | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2011 10:25 AM |
| kitchenaid triple burner always on high | toad989 | Oven Repair (including Ranges and Cooktops) | 0 | 04-11-2011 06:00 PM |
| Maytag glass top triple burner malfunctioning | LisaBurchett | Oven Repair (including Ranges and Cooktops) | 1 | 10-18-2010 08:33 AM |
| Triple element not working | wfd1746 | Oven Repair (including Ranges and Cooktops) | 0 | 01-26-2010 02:33 PM |
| Inner burner not working on triple burner | laudusk | Oven Repair (including Ranges and Cooktops) | 3 | 06-06-2009 11:26 AM |
