| » GE P7 wall oven |
Model Number: GE P7 single oven Brand: GE Age: More than 10 years
Digital clock went dark and oven and broiler will not come on. But, if oven knob is turned on to either "bake" or "broil" the clock comes on and can be reset, heater elements still do not come on and the clock goes off as soon as the oven knob is switched off. I was wondering if this is a clock replacement issue or a sign of a different problem.
Hi.
Try to reset the breaker. Most likely the oven only gets 120VAC. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Flipped breaker, no change. But based on your lead I will check lines to breaker and to the box that the oven must connect to in order to check for 2 120V lines as perhaps a connection failed. I will post what I find probably tomorrow or the next day.
| Display Modes | |
| Frigidaire Double Wall Oven Upper No Broil Lower No Oven | Jim Gaspar | Oven Repair (including Ranges and Cooktops) | 0 | 10-14-2012 12:50 PM |
| Dacor Double Wall Oven-replace lower oven relay board | CatsR | Oven Repair (including Ranges and Cooktops) | 3 | 01-28-2011 07:29 AM |
| lost bake element connector wires behind oven wall in wall oven | wdeather98 | Oven Repair (including Ranges and Cooktops) | 1 | 01-01-2011 08:24 PM |
| Jenn Air Wall Electric Wall Oven | WILLIAM SHIVER | Oven Repair (including Ranges and Cooktops) | 3 | 05-20-2009 12:56 AM |
| kitchen aid wall oven shuts off periodically when cooking with the upper oven? | eddevlin | Oven Repair (including Ranges and Cooktops) | 6 | 03-15-2009 01:55 PM |
