Discuss
Jenn Aire S136 cartridge issues
 in
I believe I have a bad cartridge on my range top (one element works, one doesn't). I have tested the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Aire S136 cartridge issues
  #1 (permalink)
Old 02-04-2013, 10:38 PM
Junior Member
son in law repairman is on a distinguished road
Default Jenn Aire S136 cartridge issues
Model Number: a125   Brand: Jenn-Air   Age: More than 10 years
I believe I have a bad cartridge on my range top (one element works, one doesn't). I have tested the terminals on the stove (with knob turned to on position and cartridge removed). It tests at 110v. is this correct?
Ads By Google
Related Models
Jenn-Air A125B Ele Cartridge
Jenn-Air A125W Ele Cartridge
Jenn-Air A126B Ele Cartridge
Jenn-Air A126W Ele Cartridge
Jenn-Air A130-F Induction Cartridge
Jenn-Air A130F Induction Cartridge
Jenn-Air A130R Induction Cartridge
Jenn-Air A135-R Induction Cartridge
Jenn-Air A135F Induction Cartridge
Jenn-Air A135R Induction Cartridge
Frigidaire A13MUC2 Frg(v5) / Room Air Conditioner
Frigidaire A13MUD2 Frg(v4) / Room Air Conditioner
Jenn-Air A140 Misc / Accessory
Hoover A1408 Washer - Top Loading
Hoover A1408010 Washer - Top Loading
Jenn-Air A141-C Misc / Accessory
Hoover A1410 Washer - Top Loading
Hoover A1410010 Washer - Top Loading
Hoover A1410B Washer - Top Loading
Jenn-Air A145 Misc / Accessory
Jenn-Air A145A Misc / Accessory
Jenn-Air A150 Misc / Accessory
Jenn-Air A150-8 Misc / Accessory
Admiral A1500PRA Range - F/s Std Ele
Admiral A1500PRW Range - F/s Std Ele
Jenn-Air A151 Misc / Accessory
Jenn-Air A151-8 Misc / Accessory
Frigidaire A1538EC2 Frg(v6) / Room Air Conditioner
Frigidaire A1538UD2 Frg(v5) / Room Air Conditioner
Jenn-Air A158 Misc / Accessory
Jenn-Air A158-8 Misc / Accessory
Jenn-Air A158S Misc / Accessory
Jenn-Air A159 Misc / Accessory
Maytag A15CA Washer - Top Loading
Maytag A15CM Washer - Top Loading
Maytag A15CT Washer - Top Loading
Maytag A16CA Washer - Top Loading
Maytag A16CM Washer - Top Loading
Maytag A16CT Washer - Top Loading
Maytag A17CA Washer - Top Loading
Maytag A17CM Washer - Top Loading
Maytag A17CT Washer - Top Loading
Maytag A180 Washer - Top Loading
Maytag A181 Washer - Top Loading
Maytag A182 Washer - Top Loading
Maytag A183 Washer - Top Loading
Frigidaire A1838C2 Frg(v7) / Room Air Conditioner
Frigidaire A1838D2 Frg(v6) / Room Air Conditioner
Frigidaire A1838EC2 Frg(v1) / Room Air Conditioner
Frigidaire A1838ED2 Frg(v7) / Room Air Conditioner
Frigidaire A1838UC2 Frg(v8) / Room Air Conditioner
Frigidaire A1838UD2 Frg(v8) / Room Air Conditioner
Maytag A184T Washer - Top Loading
Maytag A18CA Washer - Top Loading
Maytag A18CM Washer - Top Loading
Maytag A18CT Washer - Top Loading
Frigidaire A18NE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A18NE2E2 Frg(v2) / Room Air Conditioner
Maytag A190 Washer - Top Loading
Maytag A190T Washer - Top Loading
Maytag A1910 Washer - Top Loading
Maytag A200 Washer - Top Loading
Maytag A200S Washer - Top Loading
Maytag A202 Washer - Top Loading
Maytag A202S Washer - Top Loading
Maytag A203 Washer - Top Loading
Maytag A203S Washer - Top Loading
Maytag A206 Washer - Top Loading
Maytag A206S Washer - Top Loading
Maytag A207 Washer - Top Loading
Maytag A207S Washer - Top Loading
Maytag A208 Washer - Top Loading
Maytag A208S Washer - Top Loading
Maytag A209 Washer - Top Loading
Maytag A209S Washer - Top Loading
Maytag A210 Washer - Top Loading
Maytag A210S Washer - Top Loading
Maytag A211 Washer - Top Loading
Maytag A211S Washer - Top Loading
Maytag A211T Washer - Top Loading
Maytag A212 Washer - Top Loading
Maytag A212S Washer - Top Loading
Maytag A212ST Washer - Top Loading
Maytag A212T Washer - Top Loading
Maytag A21CA Washer - Top Loading
Maytag A21CM Washer - Top Loading
Maytag A21CT Washer - Top Loading
Frigidaire A2238C2 Frg(v9) / Room Air Conditioner
Frigidaire A2238D2 Frg(v9) / Room Air Conditioner
Maytag A22CA Washer - Top Loading
Maytag A22CM Washer - Top Loading
Maytag A22CT Washer - Top Loading
Maytag A23CA Washer - Top Loading
Maytag A23CDL Washer - Top Loading
Maytag A23CDW Washer - Top Loading
Maytag A23CSL Washer - Top Loading
Maytag A23CSW Washer - Top Loading
Maytag A23CT Washer - Top Loading
Frigidaire A2438DC2 Frg(v10) / Room Air Conditioner
Frigidaire A2438DD2 Frg(v10) / Room Air Conditioner
Maytag A24CA Washer - Top Loading
Maytag A25CA Washer - Top Loading
Maytag A25CAE Washer - Top Loading
Maytag A25CM Washer - Top Loading
Maytag A25CME Washer - Top Loading
Maytag A25CS Washer - Top Loading
Maytag A25CT Washer - Top Loading
Maytag A26CA Washer - Top Loading
Maytag A26CAE Washer - Top Loading
Maytag A26CD Washer - Top Loading
Maytag A26CDC Washer - Top Loading
Maytag A282 Washer - Top Loading
Maytag A282T Washer - Top Loading
Maytag A283 Washer - Top Loading
Frigidaire A2838C2 Frg(v11) / Room Air Conditioner
Frigidaire A2838D2 Frg(v11) / Room Air Conditioner
Maytag A283T Washer - Top Loading
Maytag A284 Washer - Top Loading
Maytag A284T Washer - Top Loading
General Electric A2B348CKALRA Zoneline
  #2 (permalink)
Old 02-05-2013, 11:31 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
This is the 240VAC unit. With both switches on you should read 240V between two pairs of contacts and 120VAC to the ground (the round one).
If you have correct voltage only in one position then there is a bad infinite switch.
Check both receptacles in the cartridge where the elements are plugged in.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn-Air cartridge issue np5551 Oven Repair (including Ranges and Cooktops) 0 01-25-2013 09:18 AM
Jenn-air stove cartridge Low=High Csmoferret Oven Repair (including Ranges and Cooktops) 0 05-15-2012 05:04 AM
Old Jenn Air Cooktop - 6 burner (3 cartridge) Norseman00 Oven Repair (including Ranges and Cooktops) 2 07-13-2011 09:36 AM
Jenn Air Replacement cartridge mjbetz@laga.com Oven Repair (including Ranges and Cooktops) 0 02-06-2010 04:56 PM
jenn air cartridge bentfender Oven Repair (including Ranges and Cooktops) 0 03-22-2009 09:37 AM
