Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Amana Oven Fails after Power Failure (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/517262-amana-oven-fails-after-power-failure.html)
newatappliancerepair 02-04-2013 10:05 PM
Ever since the power went out, the oven displays time, and blinks "Off", but when you power it off (through the circuit breaker) you get the same state of operation. If you hit the Oven Cancel button, you can hear a beep or tone, but no other controls work. I don't see an obvious way to turn the oven off except through the circuit breaker at the main power panel. So the oven appears to be stuck in an "Off" state. :mad:
Simon / APP Team 02-05-2013 11:12 AM
Hi.
Open the control panel and pull off the flex ribbon connector from the clock board. Clean the edge with the isopropyl alcohol, let it dry and reconnect.
If that doesn't help - replace the clock board Part number: 31746801
Here is the breakdown diagram and 01-Door / Control Panel parts for Amana AOCS3040SS - AppliancePartsPros.com
Post the results.
Simon.
newatappliancerepair 02-07-2013 07:57 PM
Amana Wall Oven AOCS3040SS
Quote:
Originally Posted by Simon / APP Team (Post 798318)
Hi.
Post the results.
Simon.
Simon, I figured it out. On page 12 of the Service Manual 16021875 Rev 0, there is Component Testing Information. There is a test procedure for the Child Safety Feature for Child Lockout. By Pressing and holding BAKE and COOK TIME for 10 seconds, the Oven reset itself, and the control panel is now accessible. I guess when the power came on, the Oven went to Child Safety Mode. I happened to start reading the manual from cover to cover to try and figure this out, and noticed the note about "OFF" will display where the temperature normally appears.
-Douglas
Simon / APP Team 02-08-2013 10:40 AM
I'm glad you where able to take care of the problem without part replacement.
Thank you for shearing with us this important detail.
Simon.
newatappliancerepair 02-08-2013 11:55 AM
02/08/2013 Child Safety Features for Amana Oven AOCS3040
You are welcome. I'm all for child safety features, except when the adults get locked out! How would you ever figure this out if you did not have a copy of the service manual?
Thanks Again,
NewAtApplianceRepair
