| » Gas oven that turns itself off |
Model Number: sf357pekq Brand: Whirlpool Age: More than 10 years
I have a gas stove that when I turn the oven on it goes thru the pre-heat countdown and the timer indicates that the oven has reached the desired temp. But after awhile the oven is no longer on. When I say no longer on. The temperature settings say 350 or whatever I set it to but the oven is off. ( Stone cold) So I go back thru the process of turning it back on, it pre-heats and maybe 10-15 minutes later it is not working again. Someone says that it could be the heating element. I am unemployed and don't have money to call a repair person. Please let me know what you think this could be and what can I do to fix it.
| Display Modes | |
| Oven control panel fritzing out (turns oven back on!) | mcuth | Oven Repair (including Ranges and Cooktops) | 0 | 05-20-2011 09:05 AM |
| ge oven turns off by itself | hhu921 | Oven Repair (including Ranges and Cooktops) | 0 | 08-24-2010 09:12 AM |
| Surface Burners work OK, Oven dead, no control light turns on for oven | Whirlyone | Oven Repair (including Ranges and Cooktops) | 0 | 06-07-2010 07:24 AM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| Clock turns on when the oven is turned on but oven doesn't work | LMesey | Oven Repair (including Ranges and Cooktops) | 2 | 08-22-2008 11:20 AM |
