Discuss
Kitchen aid intermittent bake
 in
The original problem with this oven was that there was no bake or broil. The gas valve was replaced and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kitchen aid intermittent bake
  #1 (permalink)
Old 02-03-2013, 04:05 PM
Junior Member
DrMonty is on a distinguished road
Default Kitchen aid intermittent bake
Model Number: kgrs807sss   Brand: Kitchen Aid   Age: 1 - 5 years
The original problem with this oven was that there was no bake or broil. The gas valve was replaced and I confirmed that the old gas valve had failed as the bake solenoid was open. After replacing the gas valve the oven would initially ignite but was intermittent after the oven reached operating temperature. I replaced the spark ignition assembly and ignition after reaching set point is still intermittent. I can hear the spark ignition cycle 4 times and then time out and try again. I have cleaned all the mounting screws, the bake burner and any other area that may affect the ground plane as I know the DSI ovens require good grounds. The interesting part of this is that if I open the door at any time during the ignition sequence, 4 sparks, the oven ignites. Since the oven operated correctly prior to the gas valve failure, I'm wondering if this might be a gas flow issue. Would there be a possibility that there isn't enough gas, once the oven is hot, to ignite? or optionally could there be too much gas and not enough oxygen for ignition? I hate to begin shotgunning components without some explanation for the intermittent operation.
Thanks in advance for any suggestions or recommendations!
Ads By Google
Related Models
Whirlpool KGRS807SSS00 30" Freestanding Gas Oven Convection
Whirlpool KGRS807SWH00 30" Freestanding Gas Oven Convection
Whirlpool KGRT500BAL1
Whirlpool KGRT500BAL2
Whirlpool KGRT500BAL3
Whirlpool KGRT500BWH1
Whirlpool KGRT500BWH2
Whirlpool KGRT500BWH3
Whirlpool KGRT500FAL0
Whirlpool KGRT500FAL1
Whirlpool KGRT500FAL2
Whirlpool KGRT500FWH0
Whirlpool KGRT500FWH1
Whirlpool KGRT500FWH2
Whirlpool KGRT507BAL1
Whirlpool KGRT507BAL2
Whirlpool KGRT507BAL3
Whirlpool KGRT507BBL1
Whirlpool KGRT507BBL2
Whirlpool KGRT507BBL3
Whirlpool KGRT507BWH1
Whirlpool KGRT507BWH2
Whirlpool KGRT507BWH3
Whirlpool KGRT507FAL0
Whirlpool KGRT507FAL1
Whirlpool KGRT507FBL0
Whirlpool KGRT507FBL1
Whirlpool KGRT507FWH0
Whirlpool KGRT507FWH1
Whirlpool KGRT507GAL0
Whirlpool KGRT507GBL0
Whirlpool KGRT507GBS0
Whirlpool KGRT507GBT0
Whirlpool KGRT507GWH0
Whirlpool KGRT600HAL0
Whirlpool KGRT600HAL3
Whirlpool KGRT600HAL4
Whirlpool KGRT600HBL5
Whirlpool KGRT600HBL6
Whirlpool KGRT600HBL8
Whirlpool KGRT600HBL9
Whirlpool KGRT600HBT5
Whirlpool KGRT600HBT6
Whirlpool KGRT600HBT8
Whirlpool KGRT600HBT9
Whirlpool KGRT600HWH0
Whirlpool KGRT600HWH3
Whirlpool KGRT600HWH4
Whirlpool KGRT600HWH5
Whirlpool KGRT600HWH6
Whirlpool KGRT600HWH8
Whirlpool KGRT600HWH9
Whirlpool KGRT607HBL0
Whirlpool KGRT607HBL3
Whirlpool KGRT607HBL4
Whirlpool KGRT607HBL5
Whirlpool KGRT607HBL6
Whirlpool KGRT607HBL8
Whirlpool KGRT607HBL9
Whirlpool KGRT607HBS0
Whirlpool KGRT607HBS1
Whirlpool KGRT607HBS3
Whirlpool KGRT607HBS4
Whirlpool KGRT607HBS5
Whirlpool KGRT607HBS6
Whirlpool KGRT607HBS8
Whirlpool KGRT607HBS9
Whirlpool KGRT607HBT0
Whirlpool KGRT607HBT3
Whirlpool KGRT607HBT4
Whirlpool KGRT607HBT5
Whirlpool KGRT607HBT6
Whirlpool KGRT607HBT8
Whirlpool KGRT607HBT9
Whirlpool KGRT607HWH0
Whirlpool KGRT607HWH3
Whirlpool KGRT607HWH4
Whirlpool KGRT607HWH5
Whirlpool KGRT607HWH6
Whirlpool KGRT607HWH8
Whirlpool KGRT607HWH9
Whirlpool KGSA906PBL00 30" Slide - in Gas Oven Convection
Whirlpool KGSA906PBL01 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PBL02 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PBT00 30" Slide - in Gas Oven Convection
Whirlpool KGSA906PBT01 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PBT02 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PSS00 30" Slide - in Gas Oven Convection
Whirlpool KGSA906PSS01 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PSS02 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PWH00 30" Slide - in Gas Oven Convection
Whirlpool KGSA906PWH01 30" Freestanding Gas Oven Convection
Whirlpool KGSA906PWH02 30" Freestanding Gas Oven Convection
Whirlpool KGSC308LSS0 30" Slide - in Range Designer Style Convection Oven
Whirlpool KGSI901PBL00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PBL01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBL02 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBS00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PBS01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PBS02 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PSS00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PWH00 30" Slide - in Gas Oven Non - Conv
Whirlpool KGSI901PWH01 30" Freestanding Gas Oven Convection
Whirlpool KGSI901PWH02 30" Freestanding Gas Oven Convection
Whirlpool KGSK901SBL00 30" Slide - in Gas Oven
Whirlpool KGSK901SSS00 30" Slide - in Gas Oven
Whirlpool KGSK901SWH00 30" Slide - in Gas Oven
Whirlpool KGSO145E
Whirlpool KGSP145E
Whirlpool KGSS907SBL00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SBT00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SSS00 30" Slide - in Gas Oven Convection
Whirlpool KGSS907SWH00 30" Slide - in Gas Oven Convection
Whirlpool KGST300BAL0
Whirlpool KGST300BAL1
Whirlpool KGST300BAL2
Whirlpool KGST300BWH0
Whirlpool KGST300BWH1
Whirlpool KGST300BWH2
Whirlpool KGST300FAL0
  #2 (permalink)
Old 02-04-2013, 03:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by DrMonty View Post
...I can hear the spark ignition cycle 4 times and then time out and try again...
Hello,
Can you hear the gas flowing at that time?
Make sure the vent tubes are in place and are not restricted.
Here are the breakdown diagrams and Parts for Whirlpool KGRS807SSS00 Range - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-05-2013, 08:43 AM
Junior Member
Default
Hi Gene,
Thanks for responding to my question. Yes, I can hear the spark and hear/smell the gas on the unsuccessful attempt. Experimenting with flame size and air mix adjustments is difficult as the oven works, fires on first spark, most of the time when I remove the bake shield and the warmer drawer. Once I put everything back together and heat it up it is when it fails to light. I'll do a double check on the venting tonight.
Thanks,
Randy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
intermittent issues with the bake function scanman24 Oven Repair (including Ranges and Cooktops) 4 10-25-2012 08:30 AM
Intermittent heating + intermittent gas smell Steve2012 Dryer Repair 0 07-08-2012 05:24 AM
kitchen aide elec oven takes longer to bake rickharp Oven Repair (including Ranges and Cooktops) 7 10-16-2010 03:06 AM
Intermittent water leak - Kitchen Aid side by side greg88 Refrigerator & Freezer Repair 1 10-08-2009 01:13 PM
Kitchen Aid Gas, Bake start wiseguy Oven Repair (including Ranges and Cooktops) 0 12-22-2008 06:59 PM
