I am trying to diagnose which part is at fault. My touch pad or Electronic Control.
The upper oven and all controls work as they should. The lower oven all the set up's (bake, broil, time delay, clean, etc) enen the oven light touch pad switch. The only one that has a malfunction is the "Start", nothing will start for the lower oven. The cancle does work.
I do not get an error code and do not see where (or how) to connect my ohm meter to the ribbon cable to test see if the readings are in line with the diagram that came with the oven. The plun in end of the cable seems to have insulation on both sides. My diagram does not include the voltages I should get.
I would like to know which componant I will need to replace.
Thank you for any help you may be able to give. me.
Inspector34 (Bob) :cool:
