Discuss
Electric Range
 in
Whirlpool Electric Range Model # GY398LXPT00, Serial # XR5107443 I can not Bake, Broil, Auto Clean, set Temperature or set
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Range
  #1 (permalink)
Old 01-31-2013, 11:35 PM
Junior Member
Altevon is on a distinguished road
Default Electric Range
Model Number: GY398LXPT00   Brand: Whirlpool   Age: 1 - 5 years
I can not Bake, Broil, Auto Clean, set Temperature or set Cook Time.
The top cooking element work fine.
The clock and display work.
The oven light turns on/off
The buttons on the left half of the Touch pad do not work, i.e.:
Convect Bake: No
Bake: No
Custom Broil: No
Temp +/_ No
Auto Clean: No
Cook Time: No
The buttons on the right half of the Touchpad do work.
I can not Bake, Broil, Auto Clean, set Temperature or Cook Time.
However, I can preheat the oven when I press Stop Time-, than Start button.
Oven goes through PreHeat cycle to 350 deg F, booth element work. I can stop this cycle by pressing Off/Cancel.
Thank you for your help and suggestions,
Altevon
Ads By Google
Related Models
Whirlpool GY398LXPT00 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPT01 30" Slide - in Electric Oven Self Clean
Whirlpool GY398LXPT02 30" Slide - in Electric Oven Self Clean
International GZ2626GEKB Ref - SXS/I&W
International GZ2626GEKS Ref - SXS/I&W
International GZ2626GEKW Ref - SXS/I&W
International GZ2727GEHB Ref - SXS/I&W
International GZ2727GEHQ Ref - SXS/I&W
International GZ2727GEHW Ref - SXS/I&W
Whirlpool GZ5730XLB0
Whirlpool GZ5730XLQ0
Whirlpool GZ5730XLS0
Whirlpool GZ5730XLT0
Whirlpool GZ5730XRB0
Whirlpool GZ5730XRB1
Whirlpool GZ5730XRQ0
Whirlpool GZ5730XRQ1
Whirlpool GZ5730XRS0
Whirlpool GZ5730XRS1
Whirlpool GZ5730XRT0
Whirlpool GZ5730XRT1
Whirlpool GZ5736XLB0
Whirlpool GZ5736XLQ0
Whirlpool GZ5736XLS0
Whirlpool GZ5736XLT0
Whirlpool GZ5736XRB0
Whirlpool GZ5736XRB1
Whirlpool GZ5736XRQ0
Whirlpool GZ5736XRQ1
Whirlpool GZ5736XRS0
Whirlpool GZ5736XRS1
Whirlpool GZ5736XRT0
Whirlpool GZ5736XRT1
Whirlpool GZ7730XGS0
Whirlpool GZ7730XGS1 30" Range Hood (use with Gas or Electric Range)
Whirlpool GZ7736XGS0
Whirlpool GZ7736XGS1 30" Range Hood (use with Gas or Electric Range)
Whirlpool GZ7930XGS0
Whirlpool GZ7930XHS0
Whirlpool GZ7930XHS1 30" and 36" Retractable Down Draft Vent System (internal Venting)
Whirlpool GZ7936XGS0
Whirlpool GZ7936XHS0
Whirlpool GZ7936XHS1 30" and 36" Retractable Down Draft Vent System (internal Venting)
Whirlpool GZ8330XLS0 30" & 36" Range Hood (vented) (use with Gas or E
Whirlpool GZ8330XLS1 30" & 36" Range
Whirlpool GZ8336XLS0 30" & 36" Range Hood (vented) (use with Gas or E
Whirlpool GZ8336XLS1 30" & 36" Range
Bosch GZ900-060
Bosch GZ936-010
Whirlpool GZ9730SSS0 30" & 36" Hood
Whirlpool GZ9730XSS0 30" & 36" Hood
Whirlpool GZ9736SSS0 30" & 36" Hood
Whirlpool GZ9736XSS0 30" & 36" Hood
Bosch GZ990-010
Bosch GZ991-010
Bosch GZ992-010
Hardwick H-414 Surface Unit - Gas
Hardwick H-434 Surface Unit - Gas
Hardwick H-444 Surface Unit - Gas
Hardwick H-445 Surface Unit - Ele
Hardwick H-446 Surface Unit - Gas
Thermador H-62
Thermador H-62A
Thermador H-63
Thermador H-63A
Thermador H-64
Thermador H-65
Thermador H-66
Thermador H-66A
Thermador H-67
Thermador H-67A
Thermador H-71
Thermador H-76
Thermador H-98
Hoover H1005---
Hardwick H1100PAW Range - F/s Std Gas
Hardwick H1100PRA Range - F/s Std Gas
Hardwick H1100PRA-K Range - F/s Std Gas
Hardwick H1100PRW Range - F/s Std Gas
Hardwick H1100PRW-K Range - F/s Std Gas
Hardwick H1500PRA Range - F/s Std Ele
Hardwick H1500PRW Range - F/s Std Ele
Frigidaire H15A Frg(v1) / Chest Freezer
Frigidaire H15B Frg(v2) / Chest Freezer
Frigidaire H15C Frg(v3) / Chest Freezer
Frigidaire H20A Frg(v1) / Chest Freezer
Frigidaire H20B Frg(v2) / Chest Freezer
Frigidaire H23A Frg(v1) / Chest Freezer
Frigidaire H23B Frg(v2) / Chest Freezer
Hoover H2510
Hoover H2800--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H2800050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H28010RM Uprt - Hd,lc,mid,gns,ns,gmn,pr As,com,id
Hoover H2850 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H2850050 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000001 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000006 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000011 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3000020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H30010RM Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3010--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3010020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3012020 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Maytag H302RA Hood
Maytag H302RB Hood
Maytag H302RQ Hood
Maytag H302RS Hood
Maytag H302RW Hood
Hoover H3030--- Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3030001 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Hoover H3030006 Hand - Hm,wet/dry,w/agt,twist,hd Flr Brz
Maytag H303RA Hood
Maytag H303RB Hood
Maytag H303RQ Hood
Maytag H303RS Hood
Maytag H303RW Hood
Maytag H304RA Hood
Maytag H304RB Hood
Maytag H304RQ Hood
  #2 (permalink)
Old 02-01-2013, 03:13 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Parts for Whirlpool GY398LXPT00 Range - AppliancePartsPros.com
The problem could be the control panel (keypad) or the electronic control (timer).
The usual way to troubleshoot this is to check the keypad outputs and if they are OK then replace the timer. But I cannot find info on the actual keypad outputs so unless you have some experience troubleshooting keypads this will not be an option.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If this does nothing then pretty well all you can do is take a gamble on one of the parts.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
electric range patrickz63 Oven Repair (including Ranges and Cooktops) 0 01-24-2012 04:00 PM
ge electric range linda kolonsky Oven Repair (including Ranges and Cooktops) 1 07-29-2011 04:47 AM
electric range jak Oven Repair (including Ranges and Cooktops) 0 10-02-2008 05:01 AM
ge electric range lyle w. royal Oven Repair (including Ranges and Cooktops) 1 07-30-2008 03:23 PM
Electric Range TREFFJ Oven Repair (including Ranges and Cooktops) 4 01-15-2008 11:35 AM
