| » Whirlpool Oven Not Heating Properly |
Model Number: RF380LXKQ Brand: Whirlpool Age: 5 - 10 years
My Whirlpool Super Capacity 465 (RF380LXKQ) electric range is not heating properly. I used a digital meat thermometer suspended below the middle rack to check temperature. This way I could have the display outside while the door was closed. When set to a temperature the preheat indicator comes on and the oven counts down the time till ready. However when the time hits zero it is not at the proper temperature. If I set it for 400F it will only be 300F when the time ends. If I raise temperature to 415F it will eventually settle out around 400F. I tried using the Oven Temperature Control adjustment in the manual but the amount that it is off by changes with temperature. In order to get it to settle around 450F I had to have the oven set to 470F. Any suggestion on what the problem is / how to troubleshoot it? I really don't want to buy a new oven. Ads By Google Related Models |
Hello,
Check the oven sensor for continuity at the control board connector. The normal reading suppose to be about 1100 Ohms at the room temperature. If the reading is incorrect, replace the oven sensor. If the reading is correct, replace the oven control board. - The oven sensor Part number: W10181986 - The oven control board Part number: 6610316 Here are the breakdown diagrams and Parts for Whirlpool RF380LXKQ0 Range - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Oven not properly heating up. | GRLauer | Oven Repair (including Ranges and Cooktops) | 1 | 12-24-2012 05:02 AM |
| Whirlpool stacked dryer heating but not drying properly | juliog | Dryer Repair | 1 | 01-06-2012 06:07 AM |
| oven not heating properly | clmartin22 | Oven Repair (including Ranges and Cooktops) | 0 | 10-20-2011 09:57 AM |
| Whirlpool oven RF365PXXN0 not heating properly | dcllf | Oven Repair (including Ranges and Cooktops) | 3 | 08-25-2010 03:48 PM |
| Whirlpool Oven Not Heating Properly | Jinsmom | Oven Repair (including Ranges and Cooktops) | 1 | 01-12-2010 02:54 AM |
