Discuss
Right Front Burner Doesn't Work
 in
The right front burner doesn't wont light up. I believe the potentiometer may be the cause but not sure.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Right Front Burner Doesn't Work
  #1 (permalink)
Old 02-04-2008, 10:59 AM
Babdiver Babdiver is offline
Junior Member
Babdiver is on a distinguished road
Default Right Front Burner Doesn't Work
Model Number: SGCS304RS   Brand: Thermador   Age: 5 - 10 years
The right front burner doesn't wont light up. I believe the potentiometer may be the cause but not sure. Is there an adjustment screw or something to adjust the burner? I am not sure how to remove the Stainless Steel top to get at the inside.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 07:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Looking at the break down diagram I do not think the right front burner has the potentiometer.
Looks like this the regular ignition switch.
Before we will go further I need to know what's going on when you turn the knob "on"?
Does it open the gas?
Does it click?
Does it spark?
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-05-2008, 04:00 PM
Junior Member
Default
The right front burner is clicking and sparking but no gas comes on.
  #4 (permalink)
Old 02-05-2008, 06:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does this burner have XLO?
__________________
  #5 (permalink)
Old 04-30-2008, 06:00 PM
bayomom bayomom is offline
Junior Member
bayomom is on a distinguished road
Default
Quote:
I am having this exact problem -- same burner and it does have XLO. Any further info?Thanks so much.
  #6 (permalink)
Old 04-30-2008, 06:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
bayomom,
Can you be more specific on the problem?
What is the complete model number of the unit?
__________________
  #7 (permalink)
Old 04-30-2008, 09:01 PM
Junior Member
Default
Hi Gene -- Thanks for the quick reply. Thermador Model #SGCS304RW
The right front burner (with XLO feature) will spark and igniter clicks but no gas flows. All 3 other burners work correctly. This cooktop was installed elsewhere and just recently reinstalled in our kitchen and we smell the barest whiff of gas under the counter (nearly imperceptible) after attempting to light this burner.
Thanks again for any guidance you can provide.
  #8 (permalink)
Old 05-01-2008, 04:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The first thing I would do is unplug the stove power cord, turn all knobs to "off" position, wait a few minutes and plug the power cord back. See if it's working.
If it did not help then you have to check the gas solenoid for this burner (# 10 on the gas and electric parts break down diagram).
To access the solenoid you have to remove the top panel (remove all burners and knobs first).
Remove both wires from the solenoid and measure the resistance. It suppose to be 1760 Ohms ± 20%.
If the reading is wrong - replace the solenoid.
If the reading is correct then the potentiometer is bad and has to be replaced. Thermador redesigned this part and the new kit (consists of both new potentiometers and the simmer control module) has to be installed.
- The part number for the gas solenoid is AP2828839
- The part number for the potentiometer kit is AP3872616
Here are the break down diagrams for the Thermador stove Model SGCS304RW
__________________
  #9 (permalink)
Old 05-01-2008, 07:50 PM
Junior Member
Default
Thanks so much for the tips. We'll follow your recommendations to see what it might be and post back when we know!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to add a simmer burner? rcmizen Oven Repair (including Ranges and Cooktops) 1 04-05-2008 06:51 PM
Large burner doesn't work, red "on" light stays lit Cath Oven Repair (including Ranges and Cooktops) 0 01-30-2008 08:30 AM
Burner won't fire up warezaholic Dryer Repair 2 12-02-2007 05:22 PM
burner gets hot. raman Oven Repair (including Ranges and Cooktops) 1 11-27-2007 04:49 PM
Burner on a Flat top mckrsix Oven Repair (including Ranges and Cooktops) 9 10-15-2007 04:17 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
