Discuss
lower oven element isn't working
 in
Lower oven is not working. clock board has power. Can turn on lower oven, but element will not get hot.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » lower oven element isn't working
  #1 (permalink)
Old 01-29-2013, 10:31 PM
Junior Member
georgewade is on a distinguished road
Default lower oven element isn't working
Model Number: ffet2725lsa   Brand: Frigidaire   Age: 1 - 5 years
Lower oven is not working. clock board has power. Can turn on lower oven, but element will not get hot. Pulled element out and turned on lower oven, volt reading across connections at element is zero, volt reading at either end of element is 105volts to ground(one side has some power). Upper oven works. Swapped temperature sensors, both work in upper oven. Cooling fan works when either oven is turned on. Is the relay on the 'relay-board' bad for the lower oven element or is another terminal/connector between the relay board and element. I haven't pulled the oven out. So what are your thoughts?
Related Models
Frigidaire FFET2725LSA WALLOVEN
Frigidaire FFET2725LWA WALLOVEN
Frigidaire FFET3025LBA WALL OVEN
Frigidaire FFET3025LSA WALL OVEN
Frigidaire FFET3025LWA WALL OVEN
Frigidaire FFEW2425LSA WALLOVEN
Frigidaire FFEW2725LBA WALLOVEN
Frigidaire FFEW2725LBB WALLOVEN
Frigidaire FFEW2725LSA WALLOVEN
Frigidaire FFEW2725LSB WALLOVEN
Frigidaire FFEW2725LWA WALLOVEN
Frigidaire FFEW2725LWB WALLOVEN
Frigidaire FFEW3025LBA WALLOVEN
Frigidaire FFEW3025LSA WALLOVEN
Frigidaire FFEW3025LWA WALLOVEN
Frigidaire FFF318AWA Frigidaire/range
Frigidaire FFF335ESF ELECTRIC RANGE
Frigidaire FFF384HCA ELECTRIC RANGE
Frigidaire FFF384HCB ELECTRIC RANGE
Frigidaire FFFC04M1LW FREEZER
Frigidaire FFFC05M1LW FREEZER
Frigidaire FFFC05M2KW FREEZER
Frigidaire FFFC07M1LW FREEZER
Frigidaire FFFC07M2KW FREEZER
Frigidaire FFGC2605LWA COOKTOP
Frigidaire FFGC3005LWA COOKTOP
Frigidaire FFGC3015LBA COOKTOP
Frigidaire FFGC3015LBB COOKTOP
Frigidaire FFGC3015LSA COOKTOP
Frigidaire FFGC3015LSB COOKTOP
Frigidaire FFGC3015LWA COOKTOP
Frigidaire FFGC3015LWB COOKTOP
Frigidaire FFGC3025LBA COOKTOP
Frigidaire FFGC3025LBB COOKTOP
Frigidaire FFGC3025LSA COOKTOP
Frigidaire FFGC3025LSB COOKTOP
Frigidaire FFGC3025LWA COOKTOP
Frigidaire FFGC3025LWB COOKTOP
Frigidaire FFGC3603LWA COOKTOP
Frigidaire FFGC3613LBA GAS COOKTOP
Frigidaire FFGC3613LBB GAS COOKTOP
Frigidaire FFGC3613LSA GAS COOKTOP
Frigidaire FFGC3613LSB GAS COOKTOP
Frigidaire FFGC3613LWA GAS COOKTOP
Frigidaire FFGC3613LWB GAS COOKTOP
Frigidaire FFGC3625LBA COOKTOP
Frigidaire FFGC3625LBB COOKTOP
Frigidaire FFGC3625LSA COOKTOP
Frigidaire FFGC3625LSB COOKTOP
Frigidaire FFGC3625LWA COOKTOP
Frigidaire FFGC3625LWB COOKTOP
Frigidaire FFGF3000MWA GAS RANGE
Frigidaire FFGF3005MQA GAS RANGE
Frigidaire FFGF3005MWA GAS RANGE
Frigidaire FFGF3011LBA GAS RANGE
Frigidaire FFGF3011LBB GAS RANGE
Frigidaire FFGF3011LBC GAS RANGE
Frigidaire FFGF3011LWA GAS RANGE
Frigidaire FFGF3011LWB GAS RANGE
Frigidaire FFGF3011LWC GAS RANGE
Frigidaire FFGF3013LBA GAS RANGE
Frigidaire FFGF3013LBB GAS RANGE
Frigidaire FFGF3013LBC GAS RANGE
Frigidaire FFGF3013LBD GAS RANGE
Frigidaire FFGF3013LWA GAS RANGE
Frigidaire FFGF3013LWB GAS RANGE
Frigidaire FFGF3013LWC GAS RANGE
Frigidaire FFGF3013LWD GAS RANGE
Frigidaire FFGF3015LBA GAS RANGE
Frigidaire FFGF3015LBB GAS RANGE
Frigidaire FFGF3015LBC GAS RANGE
Frigidaire FFGF3015LBD GAS RANGE
Frigidaire FFGF3015LMA GAS RANGE
Frigidaire FFGF3015LMB GAS RANGE
Frigidaire FFGF3015LMC GAS RANGE
Frigidaire FFGF3015LMD GAS RANGE
Frigidaire FFGF3015LWA GAS RANGE
Frigidaire FFGF3015LWB GAS RANGE
Frigidaire FFGF3015LWC GAS RANGE
Frigidaire FFGF3015LWD GAS RANGE
Frigidaire FFGF3017LBA GAS RANGE
Frigidaire FFGF3017LBB GAS RANGE
Frigidaire FFGF3017LBC GAS RANGE
Frigidaire FFGF3017LBD GAS RANGE
Frigidaire FFGF3017LSB GAS RANGE
Frigidaire FFGF3017LSC GAS RANGE
Frigidaire FFGF3017LWA GAS RANGE
Frigidaire FFGF3017LWB GAS RANGE
Frigidaire FFGF3017LWC GAS RANGE
Frigidaire FFGF3017LWD GAS RANGE
Frigidaire FFGF3019LWA GAS RANGE
Frigidaire FFGF3019LWB GAS RANGE
Frigidaire FFGF3019LWC GAS RANGE
Frigidaire FFGF3019LWD GAS RANGE
Frigidaire FFGF3021LBA GAS RANGE
Frigidaire FFGF3021LBB GAS RANGE
Frigidaire FFGF3021LBC GAS RANGE
Frigidaire FFGF3021LWA GAS RANGE
Frigidaire FFGF3021LWB GAS RANGE
Frigidaire FFGF3021LWC GAS RANGE
Frigidaire FFGF3023LBA GAS RANGE
Frigidaire FFGF3023LBB GAS RANGE
Frigidaire FFGF3023LBC GAS RANGE
Frigidaire FFGF3023LMA GAS RANGE
Frigidaire FFGF3023LMB GAS RANGE
Frigidaire FFGF3023LMC GAS RANGE
Frigidaire FFGF3023LQA GAS RANGE
Frigidaire FFGF3023LQB GAS RANGE
Frigidaire FFGF3023LQC GAS RANGE
Frigidaire FFGF3023LSA GAS RANGE
Frigidaire FFGF3023LSC GAS RANGE
Frigidaire FFGF3023LWA GAS RANGE
Frigidaire FFGF3023LWB GAS RANGE
Frigidaire FFGF3023LWC GAS RANGE
Frigidaire FFGF3027LBA GAS RANGE
Frigidaire FFGF3027LBB GAS RANGE
Frigidaire FFGF3027LSA GAS RANGE
Frigidaire FFGF3027LSB GAS RANGE
Frigidaire FFGF3027LSC GAS RANGE
Frigidaire FFGF3027LWA GAS RANGE
  #2 (permalink)
Old 01-30-2013, 04:30 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire FFET2725LSA Wall Oven - AppliancePartsPros.com
See the attachment for the wiring diagram.
Could be that the thermal circuit breaker has opened.
Remove power from the unit and check it with a meter, should be 0 ohms.
I think it is item 119 in the Lower Oven Parts section.
I am not 100% sure so trace the wires back to the elements to confirm this is the correct part.
Also if you click on the part's picture a new page will open with better views etc. You will see that it has a red square on it's back. If this is popped out pushing it back in should reset the breaker.
Some breakers do not have this unit so do not be surprised if yours does not.
__________________
  #3 (permalink)
Old 01-30-2013, 11:19 AM
Junior Member
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #4 (permalink)
Old 01-30-2013, 11:26 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
I saw the thermal breaker on the diagram. Am going back over today to pull oven to get to the back. I suspected that may be the problem, but I needed help to pull the oven out. Since and if the 'thermal breaker' is open, what 'condition' would cause it to open and at what temp does it open?
Do you think it would be a good idea to replace the thermal breaker anyway, especially since it may not have a reset button?
  #5 (permalink)
Old 01-30-2013, 11:58 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
If both BAKE and BROIL doesn't work check the resettable safety thermostat, located at the back of the oven
Part number: 318004900
Here are the breakdown diagrams and Lower Oven parts for Frigidaire FFET2725LSA - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #6 (permalink)
Old 01-30-2013, 12:02 PM
Senior Expert
APP Volunteer
Default
I do not know at what temperature it trips.
One cause may be that the oven sensor is bad.
Since you have swapped them check the upper oven temperature with a oven thermometer to see if it is now running hot.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Oven - lower heating element not working after self cleaning martinezpaul1 Oven Repair (including Ranges and Cooktops) 3 02-05-2013 02:11 PM
Lower Heating Element not working lonjohn Oven Repair (including Ranges and Cooktops) 0 10-20-2011 10:34 AM
lower element not working mquintela Washer Repair 0 07-22-2010 07:22 PM
Replaced upper broil element, lower bake element. Elements still not working bumdout Oven Repair (including Ranges and Cooktops) 1 11-25-2009 02:49 PM
Lower element not working debcook Oven Repair (including Ranges and Cooktops) 1 11-14-2009 07:41 PM
