| » GE Profile (JGS968SHSS) won't heat above 100F |
Model Number: JGS968SHSS Brand: GE Age: 5 - 10 years
I have a GE Profile oven and recently the oven stopped heating; in fact, it was working and while baking, I found it had cooled to 100F and now it no longer heats.
- Broiler is functional; - Control pad seems normal; - 4-hour clean cycle works; oven gets v. hot; - On Bake + Convection, the internal fan (inside the oven on the back plate) doesn't seem to come on - But there is a fan somewhere that seems to turn on when I press start I was trying to find a service manual and wondering whether there is a thermal protector that might have malfunctioned. Any helpful suggestions about how to troubleshoot are very gratefully received! If I cannot figure it out, I am prepared to call a technician, but thought I'd give this forum a whirl! Thanks for your help! Ads By Google Related Models |
Hello,
Does the Bake igniter glow? If it does not, check for 120 VAC to the igniter while the control calls for Bake and post the results. If it does then most likely the igniter itself is bad (weak). You can verify it by measuring the current drawn by the igniter. If the reading is 3.2 amps or less, replace the igniter. - The igniter Part number: WB13T10045 You missed one digit between "SH" and "SS" in the model number. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hi Gene,
Many thanks for taking the time to reply. The model number should have read: JGS968S0H6SS. I'm guessing that the igniter sits beneath the floor panel. I tried to slide that panel out but it looks like I must remove the door to allow the floor panel to slide out, forwards. Does that sound correct? If yes, can you please advise how I remove the door? I see a couple of screws on each side of it. Thank you! |
You are welcome. The instructions are attached to the post.
Here are the breakdown diagrams and Parts for GE JGS968SH6SS Range - AppliancePartsPros.com Gene.
__________________
Hi Gene,
Great information - again, many thanks. I'm getting 120V AC to the igniter. The igniter is getting red hot, not white hot. I actually removed the assembly and then put it back in again. After about 45 seconds, the burner did suddenly ignite after I placed the assembly back in the oven again. I'm thinking that my igniter is weak and on the way out. Does that sound right to you? I would have measured the current, but my little voltmeter only has a V and resistance setting. Cheers! |
You are welcome. You are on the right track. I'm sure the new igniter will fix it.
__________________
__________________
Hi Gene!
All the best! |
I'm glad to hear I could help you out. If there is anything else we can help you with, drop us a line.
__________________
| Display Modes | |
| Dryer Exit Temperature ~100F | blacklocist | Dryer Repair | 3 | 01-14-2013 12:27 PM |
| GE Profile Microwave does not heat any more | dealmaster | Microwave Repair | 7 | 10-21-2010 09:02 AM |
| GE Profile Won't Heat | timjmix11 | Dryer Repair | 0 | 07-25-2010 11:45 AM |
| ge profile oven does not heat | whispertools | Oven Repair (including Ranges and Cooktops) | 0 | 01-04-2010 05:39 AM |
| Maytag Oven no heat, LCD won't go beyond 100F | new techie | Oven Repair (including Ranges and Cooktops) | 0 | 08-08-2009 05:59 PM |
