Discuss
Oven will not heat
 in
My oven will not longer heat - the burners, warmer, clock panel, convection turns on. I changed the electronic contol
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not heat
  #1 (permalink)
Old 01-29-2013, 03:00 PM
Junior Member
Pjcibulski is on a distinguished road
Default Oven will not heat
Model Number: 7907938   Brand: Kenmore   Age: 1 - 5 years
I changed the electronic contol panel and it still isn't working.
Can you please help me with reset button, is it a sensor, or wiring?
Kenmore Elite Dual Fuel Range Model 790 7938
p/n 316417312
Pam
Ads By Google
Related Models
Kenmore 791.0  HAIR CLIPPERS
Kenmore 791.4  HAIR CLIPPERS
Kenmore 791.6102190  GAS RANGE
Kenmore 791.6102890  GAS RANGE
Kenmore 791.6112190  GAS RANGE
Kenmore 791.6112890  GAS RANGE
Kenmore 791.6162190  GAS RANGE
Kenmore 791.6162890  GAS RANGE
Kenmore 791.6262190  ELECTRIC RANGE
Kenmore 791.6262890  ELECTRIC RANGE
Kenmore 791.6272190  ELECTRIC RANGE
Kenmore 791.6272890  ELECTRIC RANGE
Kenmore 791.6302190  GAS RANGE
Kenmore 791.6302890  GAS RANGE
Kenmore 791.6412190  ELECTRIC RANGE
Kenmore 791.6412890  ELECTRIC RANGE
Kenmore 791.734891  GAS RANGE
Kenmore 791.734898  GAS RANGE
Kenmore 791.783889  GAS RANGE
Kenmore 791.7838890  KENMORE GAS RANGE
Kenmore 791.7838891  GAS RANGE
Kenmore 791.7839090  GAS RANGE
Kenmore 791.7839091  GAS RANGE
Kenmore 791.7839092  GAS RANGE
Kenmore 791.7839094  GAS RANGE
Kenmore 791.785889  GAS RANGE
Kenmore 791.7858890  KENMORE GAS RANGE
Kenmore 791.7858892  GAS RANGE
Kenmore 791.7859090  GAS RANGE
Kenmore 791.7859091  GAS RANGE
Kenmore 791.7859092  GAS RANGE
Kenmore 791.7859093  GAS RANGE
Kenmore 791.7859094  GAS RANGE
Kenmore 791.7859095  GAS RANGE
Kenmore 791.7898810  KENMORE GAS RANGE
Kenmore 791.7898814  GAS RANGE
Kenmore 791.7898815  GAS RANGE
Kenmore 791.7898884  GAS RANGE
Kenmore 791.7898885  GAS RANGE
Kenmore 791.7898894  GAS RANGE
Kenmore 791.7898895  GAS RANGE
Kenmore 791.7899010  GAS RANGE
Kenmore 791.7899011  GAS RANGE
Kenmore 791.7899012  GAS RANGE
Kenmore 791.7899080  GAS RANGE
Kenmore 791.7899081  GAS RANGE
Kenmore 791.7899082  GAS RANGE
Kenmore 791.7899090  GAS RANGE
Kenmore 791.7899091  GAS RANGE
Kenmore 791.7899092  GAS RANGE
Kenmore 791.9338911  ELECTRIC RANGE
Kenmore 791.9338913  ELECTRIC RANGE
Kenmore 791.9338981  ELECTRIC RANGE
Kenmore 791.9338983  ELECTRIC RANGE
Magic Chef 79F-5EXW
Magic Chef 79FA-5EVW
Magic Chef 79FA-5EXW
Magic Chef 79FK-5EVW
Magic Chef 79FK-5EXW Walloven - S/c Ele
Magic Chef 79FN-5EVW Walloven - S/c Ele
Magic Chef 79FN-5EXW Walloven - S/c Ele
Whirlpool 7CSE3A1
Whirlpool 7CSE3W1
Whirlpool 7CSE5A2
Whirlpool 7CSE5W2
Whirlpool 7DP840CWDB0
Whirlpool 7DP840CWDB1
Whirlpool 7DP840DWGX0
Whirlpool 7DP840SWKX0 Portable Dishwasher
Whirlpool 7DP840SWKX1 Portable Dishwasher
Whirlpool 7DP840SWSX0 Portable Dishwasher
Whirlpool 7DU1100XTSQ0 Undercounter Dishwasher
Whirlpool 7DU1100XTSS0 Undercounter Dishwasher
Whirlpool 7DU840CWDB0
Whirlpool 7DU840CWDB1
Whirlpool 7DU840DWGX0
Whirlpool 7DU850SWSQ0 Undercounter Dishwasher
Whirlpool 7DU900PCDB0
Whirlpool 7DU900PCDQ0
Whirlpool 7DU900PCDQ1
Whirlpool 7DU900PCDQ2
Whirlpool 7DU910PFGB0
Whirlpool 7DU912PFGQ0
Whirlpool 7DU920PWKB0 Undercounter Dishwasher
Whirlpool 7DU920PWKQ0 Undercounter Dishwasher
Whirlpool 7DU920PWKS0 Undercounter Dishwasher
Whirlpool 7ED0GTQXKQ00
Whirlpool 7ED0GTQXKQ01
Whirlpool 7ED0GTQXKQ02 Refrigerator
Whirlpool 7ED0GTQXMQ00 Refrigerator
Whirlpool 7ED20TKXDN00
Whirlpool 7ED20TKXDN01
Whirlpool 7ED20TKXDN02
Whirlpool 7ED20TQXFW00
Whirlpool 7ED20TQXFW01
Whirlpool 7ED20TQXFW02
Whirlpool 7ED20TQXFW03
Whirlpool 7ED20TQXFW04
Whirlpool 7ED20TQXFW05
Whirlpool 7ED22PQXDN00
Whirlpool 7ED22PQXDN01
Whirlpool 7ED22PQXFN00
Whirlpool 7ED22PQXFN01
Whirlpool 7ED22PQXFW00
Whirlpool 7ED22PQXFW01
Whirlpool 7ED25DQXFW00
Whirlpool 7ED25DQXFW01
Whirlpool 7ED25DQXFW02
Whirlpool 7ED25PQXDW00
Whirlpool 7ED25PQXDW01
Whirlpool 7ED25PQXDW02
Whirlpool 7ED27DQXDN00
Whirlpool 7ED27DQXDN01
Whirlpool 7ED27DQXDN02
Whirlpool 7ED27DQXDW02
Whirlpool 7ED27DQXFN00
Whirlpool 7ED27DQXFN01
Whirlpool 7ED27DQXFN02
Whirlpool 7ED27DQXFW00
Whirlpool 7ED27DQXFW01
  #2 (permalink)
Old 01-29-2013, 04:29 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
There is no any fuses or hi-limit thermostats in your range.
Check if there is 240VAC to the connector block.
Check the wiring harness to the elements and control board.
Simon.
PS. The model number you provided is not complete.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-30-2013, 05:11 PM
Junior Member
Default Question
Simon,
Do i have fuses? Where is the connector block? Is the wiring i need to check by the control board?
MODEL 79079383401
do u think its my wiring? where is the sensor?
Pam
  #4 (permalink)
Old 01-31-2013, 11:41 AM
Expert
Default
Hi, Pam.
I meant that there is no fuse inside your range.
You need to check at the wall outlet if there is 240VAC. You need to use the multimeter for that.
Remove the rear panel to check the wires going to the elements.
What did you replace? Was it the control board/clock or the control panel. If you didn't replace the control board, then most likely it 's the problem unless there is no proper voltage to the unit.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Oven won't heat up to pre-heat setting tmilam Oven Repair (including Ranges and Cooktops) 0 04-24-2011 04:48 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 01:22 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
