Discuss
oven gas smell
 in
I replaced the oven ignitor and the oven still smells like gas when i try starting it. the oven eventually
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven gas smell
  #1 (permalink)
Old 09-30-2009, 03:50 PM
Junior Member
stephen wensman is on a distinguished road
Default oven gas smell
Model Number: kgst307bbl2   Brand: Kitchen Aid   Age: 1 - 5 years
I replaced the oven ignitor and the oven still smells like gas when i try starting it. the oven eventually heats up, but it appears to be very inefficient.
What else might I try?
Related Models
Whirlpool KGST307BBL2 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BWH0 30" GAS SLIDE-IN RANGE
Whirlpool KGST307BWH1 30" SLIDE-IN GAS RANGE
Whirlpool KGST307BWH2 30" SLIDE-IN GAS RANGE
Whirlpool KGST307FAL0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FAL1 30" SLIDE-IN RANGE
Whirlpool KGST307FBL0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FBL1 30" SLIDE-IN RANGE
Whirlpool KGST307FWH0 30" SLIDE IN CONV. OVEN
Whirlpool KGST307FWH1 30" SLIDE-IN RANGE
Whirlpool KGST307GAL0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GBL0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GBS0 30" SLIDE-IN RANGE
Whirlpool KGST307GBT0 30" SLIDE-IN COVECTION RANGE
Whirlpool KGST307GWH0 30" SLIDE-IN RANGE
Whirlpool KGST307HBL0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL2 GAS SLIDE IN RANGE
Whirlpool KGST307HBL3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBL5 SLIDE-IN RANGE,GAS
Whirlpool KGST307HBL6 RANGE
Whirlpool KGST307HBL8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBL9 GAS SLIDE IN RANGE
Whirlpool KGST307HBS0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS1 GAS RANGE
Whirlpool KGST307HBS2 GAS SLIDE IN RANGE
Whirlpool KGST307HBS3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBS5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBS6 RANGE
Whirlpool KGST307HBS8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBS9 GAS SLIDE IN RANGE
Whirlpool KGST307HBT0 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT2 GAS SLIDE IN RANGE
Whirlpool KGST307HBT3 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT4 GAS SLIDE-IN RANGE
Whirlpool KGST307HBT5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HBT6 RANGE
Whirlpool KGST307HBT8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HBT9 GAS SLIDE IN RANGE
Whirlpool KGST307HWH0 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH2 GAS SLIDE IN RANGE
Whirlpool KGST307HWH3 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH4 GAS SLIDE-IN RANGE
Whirlpool KGST307HWH5 SLIDE-IN RANGE, GAS
Whirlpool KGST307HWH6 RANGE
Whirlpool KGST307HWH8 30" SLIDE IN GAS RANGE
Whirlpool KGST307HWH9 GAS SLIDE IN RANGE
Amana KGT-591 RANGE- S/C S/I DDRAFT GAS
Amana KGT-593 RANGE- S/C S/I DDRAFT GAS
Amana KGT-693 RANGE- S/C S/I DDRAFT GAS
Amana KGT341 SURFACE UNIT- GAS
KitchenAid KGTC366EAL0 36" GAS GLASS BURNER COOKTOP
Admiral KGU5700BS REF - SXS
Admiral KGU57990KD REF - SXS/I&W
Admiral KGU5950BS REF - SXS
Admiral KGU5955BS REF - SXS
Admiral KGU6465BS REF - SXS/I&W
Admiral KGU6650 REF - SXS/I&W
Admiral KGU6651 REF - SXS/I&W
Admiral KGU6655 REF - SXS/I&W
Admiral KGU66920 REF - SXS/I&W
Admiral KGU6695 REF - SXS/I&W
Admiral KGU66990 REF - SXS/I&W
Admiral KGU6700BS REF - SXS/I&W
Admiral KGU6940BS REF - SXS/I&W
Admiral KGU6945BS REF - SXS/I&W
Whirlpool KGYE550VWH0 Residential Dryer
Whirlpool KGYE560WAL0
Whirlpool KGYE560WHT0
Whirlpool KGYE560WPL0
Whirlpool KGYE560WTO0
Whirlpool KGYE560WWH0 Residential Dryer
Whirlpool KGYE650VAL0
Whirlpool KGYE650VHT0
Whirlpool KGYE650VPL0
Whirlpool KGYE650VTO0
Whirlpool KGYE650VWH0 Residential Dryer
Whirlpool KGYE660WAL0 GAS DRYER
Whirlpool KGYE660WAL1
Whirlpool KGYE660WHT0 GAS DRYER
Whirlpool KGYE660WPL0 GAS DRYER
Whirlpool KGYE660WTO0 GAS DRYER
Whirlpool KGYE660WWH0 Residential Dryer
Whirlpool KGYE660WWH1 Residential Dryer
Whirlpool KGYE664WWH0 Residential Dryer
Whirlpool KGYE664WWH1 Residential Dryer
Whirlpool KGYE665BAL0 GAS DRYER
Whirlpool KGYE665BAL1 GAS DRYER
Whirlpool KGYE665BWH0 GAS DRYER
Whirlpool KGYE665BWH1 GAS DRYER
Whirlpool KGYE665BWH3 GAS DRYER
Whirlpool KGYE670BAL0 GAS DRYER
Whirlpool KGYE670BAL1 GAS DRYER
Whirlpool KGYE670BAL2 GAS DRYER
Whirlpool KGYE670BAL3 GAS DRYER
Whirlpool KGYE670BWH0 GAS DRYER
Whirlpool KGYE670BWH1 GAS DRYER
Whirlpool KGYE670BWH2 GAS DRYER
Whirlpool KGYE670BWH3 GAS DRYER
Whirlpool KGYE677BWH0 GAS DRYER
Whirlpool KGYE677BWH1 GAS DRYER
Whirlpool KGYE677BWH2 GAS DRYER
Whirlpool KGYE677BWH3 GAS DRYER
Whirlpool KGYE678BAL0 GAS DRYER
Whirlpool KGYE678BAL1 GAS DRYER
Whirlpool KGYE679BBL0 GAS DRYER
Whirlpool KGYE679BBL1 GAS DRYER
Whirlpool KGYE700TWH0 Residential Dryer
Whirlpool KGYE750VWH0 Residential Dryer
Whirlpool KGYE760WAL0 GAS DRYER
Whirlpool KGYE760WAL1 DRYER
Whirlpool KGYE760WHT0 GAS DRYER
Whirlpool KGYE760WPL0 GAS DRYER
Whirlpool KGYE760WTO0 GAS DRYER
Whirlpool KGYE760WWH0 Residential Dryer
Whirlpool KGYE760WWH1 Residential Dryer
Whirlpool KGYE767WWH0 Residential Dryer
Whirlpool KGYE770BAL0 GAS DRYER
Whirlpool KGYE770BAL1 GAS DRYER
  #2 (permalink)
Old 10-01-2009, 03:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What was the original problem?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-01-2009, 04:43 PM
Junior Member
Default
Quote:
when I hit bake, the room smelled like gas and the stove took a long time to heat up. It seems a bit better, but I am unsure if the ignitor was the solution.
I also have a problem with the range. some of the range ignitors spark when others are turned on. In one case, I need to turn on the front right to get the rear left to turn on. It is very strange.
  #4 (permalink)
Old 10-02-2009, 01:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by stephen wensman View Post
1. when I hit bake, the room smelled like gas and the stove took a long time to heat up. It seems a bit better, but I am unsure if the ignitor was the solution.
2. I also have a problem with the range. some of the range ignitors spark when others are turned on.
3. In one case, I need to turn on the front right to get the rear left to turn on. It is very strange.
1. How long takes to light up the Bake burner since you turn the control "on"?
2. All top igniters are on the same circuit and they all must spark when anyone turned "on".
3. Possible the ignition switch for the rear left burner is bad.
Here are the breakdown diagrams and Appliance Parts Pros
__________________
  #5 (permalink)
Old 10-02-2009, 01:35 PM
Junior Member
Default
I will time the oven as it warms up next time. If there is gas smell, what else could it be?
Stephen
  #6 (permalink)
Old 10-02-2009, 01:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Stephen,
Normal ignition time, especially with the new igniter, suppose to be within 60 seconds. By the way, this smell could be similar to gas, but caused by something else.
In order to confirm what is it exactly and where it's coming from you may want to call a local gas company to perform the leak test. This service is free of charge.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
funny smell from oven riccir Oven Repair (including Ranges and Cooktops) 0 11-16-2009 03:37 PM
gas smell when oven is off darlar2288 Oven Repair (including Ranges and Cooktops) 1 06-01-2009 01:41 PM
gas smell from oven nothing2it Oven Repair (including Ranges and Cooktops) 7 12-29-2008 11:07 AM
gas smell only when oven is on stevencsmith Oven Repair (including Ranges and Cooktops) 1 12-03-2007 11:23 PM
Oven Will not heat, no smell of gas bobafett2805 Oven Repair (including Ranges and Cooktops) 0 10-21-2007 08:11 AM
