Discuss
Removing old GE, replacing with glass top
 in
I'm looking for help in my kitchen. Sorry if this is the wrong place, but I've had such great help
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Removing old GE, replacing with glass top
  #1 (permalink)
Old 01-23-2013, 11:12 AM
Junior Member
dorn27 is on a distinguished road
Default Removing old GE, replacing with glass top
Brand: GE   Age: More than 10 years
I'm looking for help in my kitchen. Sorry if this is the wrong place, but I've had such great help here over the years.
I currently have an old, mostly unworking 1950's pink drop in range. It has more parts broken than worth fixing for my needs. Plus it's pink and it's just time to go, charm has worn off. Heats uneven, uses tons of energy, the list is huge. Plus, it's 27 inches wide and the size is long outdated. I'm not into retro, so it can go.
So, since the oven just recently died, at the time of year I'm quite broke (we don't have kids, and I pay other peoples tax returns instead of getting one)... I decided a "new to me" used stove was a good idea.
I have to widen the opening where the stove will sit. For now, that basically involves removing a set of cabinet drawers until I can afford to rework the area better.
Then I'm going to have to figure out how to remove the old thing. It has wall mounted controls and I'm told it will be wired directly into the power supply instead of having a plug.
Next, most important, I need help installing a new outlet that will work with my new stove.
Most of this I can handle. I've done some electrical work and I understand the basics. But the biggest on my own projects I've done are rewiring switches and replacing fixtures.
I however don't have a clue how to approach a big ol' range outlet. Or how to do it if there isn't a box already there?
I don't think it will be hard to remove one of my old cupboards and a little bit of counter. Nor do I think it will be hard to remove the "body" of my stove. I'm concerned about removing the control panel mounted in wall.
While I'm not keeping it, I may try to list the pink oven on craigslist and I want to reduce the damage I do to it to keep any of it retail value.
Any tips if you have removed an old built in oven? Any tips or links to what I should expect when rewiring and installing the new power recepticle?
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
removing broken glass from dishwasher martyb Dishwasher Repair 0 07-04-2010 06:58 AM
Removing glass stove cooktop oldbowler Oven Repair (including Ranges and Cooktops) 0 02-09-2010 12:06 PM
Replacing Maytag glass cootktop element does switch need replacing too? rneumann1962 Oven Repair (including Ranges and Cooktops) 1 01-18-2010 10:19 AM
GE Spacemaker glass removing BarbaraH Microwave Repair 0 07-11-2009 09:44 AM
Removing Glass panel jimhammer1 Oven Repair (including Ranges and Cooktops) 1 05-15-2008 09:52 PM
