Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   Oven preheats to set temp.but will not maintain heat igniter glows but will not relat (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/516084-oven-preheats-set-temp-but-will-not-maintain-heat-igniter-glows-but-will-not-relat.html)
Barcat 01-23-2013 07:03 AM
Oven preheats to set temp. After that when it call for heat the igniter glows but will not relight burner to maintain temp
Simon / APP Team 01-23-2013 09:50 AM
Hi.
Assuming that the top burners are working, then:
Most likely the ignitor is weak and not opening the gas valve.
To check it use the clamp on amp meter. To open the valve the ignitor should draw minimum of 3.2amp.If it's less then that - replace the ignitor Part number: WB13K21
If the amps are grater then 3.2 - replace the gas valve
Part number: WB19K36
Good luck. Post the results.
Simon.
