bottom burner stays on high it was working fine cleaned the oven now bottom burner wont regulate heat always high
:confused: Originally Posted by: les glazier bottom burner stays on high it was working fine cleaned the oven now bottom burner wont regulate heat always high
The model number you posted is incorrect. Verify and repost it.
