| » Oven door won't lock |
Model Number: JRP03G006BG Brand: GE Age: More than 10 years
I have a GE P7 electric wall oven. To start the self clean cycle I have to push a button and slide a lever to lock the door. It is impossible to slide the lever to the locked position.
Hi, David.
When you push the button do you hear the 'click"? If you do - check the latch handle, it may be bent out of shape. If there is no clicking sound you need to check if the latch solenoid is getting 120VAC when the button is pushed. Replace the solenoid if it's burnt Part number: WB24X5097 Here are the breakdown diagrams and Replacement parts for GE JRP03G0J3 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I jiggled the wires around and now I hear the click of the solenoid when I push the button and am able to close and open the locking latch. So now I know to check the solenoid next time this problem happens. I also know that it's getting 110 volts so I need to be careful working around the parts.
Thanks for the quick response! Last edited by davidgpo : 01-27-2013 at 10:18 PM. Reason: spell check |
You are welcome.
Simon.
__________________
| Display Modes | |
| Microwave Oven door lock does not lock thr door | Irving | Microwave Repair | 0 | 04-11-2012 08:59 PM |
| oven door lock loose/ "lock' Flashing | Tiaya | Oven Repair (including Ranges and Cooktops) | 0 | 04-02-2011 10:46 PM |
| Oven Door Lock | rpolsdorfer | Oven Repair (including Ranges and Cooktops) | 5 | 05-14-2010 05:52 PM |
| F9 code Oven turns off,lock light turns on,door does not lock | darling132 | Oven Repair (including Ranges and Cooktops) | 1 | 11-12-2008 02:06 PM |
| oven door will not lock | Dennis Loose | Oven Repair (including Ranges and Cooktops) | 0 | 10-08-2007 05:37 PM |
