Discuss
Power & continuity but no Heat!!
 in
Hi! The elements in my old oven stopped working one day. I got out my multimeter and there's 120V to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Power & continuity but no Heat!!
  #1 (permalink)
Old 01-21-2013, 06:31 AM
Junior Member
stockgoblin is on a distinguished road
Default Power & continuity but no Heat!!
Model Number: Moffat Fiesta 100   Brand: -other-   Age: More than 10 years
Hi!
The elements in my old oven stopped working one day. I got out my multimeter and there's 120V to the element terminals. I unhooked the terminals and checked continuity. It's at 22.6 ohms. What else should there be? I checked that the ground is good. The oven elements just won't heat up. I find it odd that both elements would give up working at the same time. The only thing that is weird is when I turn on the oven element to say 350, there's 120V to it as well as to the broiler element. Should that be or should it be to only one?
Any ideas what could be wrong?
Power & continuity + a good ground. What else?
Ads By Google
Related Models
Amana MP1.A Commercial Microwaves
Amana MP1.B Commercial Microwaves
Amana MPD218-02 Mwave - Family Size (60 Hz)
Amana MPD219-02 Mwave - Family Size (60 Hz)
Frigidaire MPF200PBDA Frg(v2) / Gas Range
Frigidaire MPF200PBWA Frg(v1) / Gas Range
Frigidaire MPF300BPDA Gib(v9) / Gas Range
Frigidaire MPF300PBDA Frg(v1) / Gas Range
Frigidaire MPF300PBDB Wwh(v1) / Gas Range
Frigidaire MPF300PBDC Frg(v1) / Gas Range
Frigidaire MPF300PBDD Frg(v1) / Gas Range
Frigidaire MPF300PBDE Frg(v1) / Gas Range
Frigidaire MPF300PBDF Frg(v1) / Gas Range
Frigidaire MPF300PBWA Frg(v2) / Gas Range
Frigidaire MPF300PBWB Wwh(v2) / Gas Range
Frigidaire MPF300PBWC Frg(v2) / Gas Range
Frigidaire MPF300PBWD Frg(v2) / Gas Range
Frigidaire MPF300PBWE Frg(v2) / Gas Range
Frigidaire MPF300PBWF Frg(v2) / Gas Range
Frigidaire MPF300PXWA Frg(v0) / Gas Range
Frigidaire MPF300PXWB Frg(v3) / Gas Range
Frigidaire MPF300PXWC Frg(v0) / Gas Range
Uni MPF300PXWG Universal/gas Range
Uni MPF300PXWH Universal/gas Range
Uni MPF300PXWJ Universal/gas Range
Frigidaire MPF303PGDA Frg(v3) / Gas Range
Frigidaire MPF303PGDD Frg(v5) / Gas Range
Uni MPF303PGDF Universal/gas Range
Uni MPF303PGDG Universal/gas Range
Uni MPF303PGDH Universal/gas Range
Frigidaire MPF303PGWA Frg(v4) / Gas Range
Frigidaire MPF303PGWC Frg(v6) / Gas Range
Frigidaire MPF303PGWD Frg(v7) / Gas Range
Uni MPF303PGWF Universal/gas Range
Uni MPF303PGWG Universal/gas Range
Uni MPF303PGWH Universal/gas Range
Frigidaire MPF311PCDA Tap(v1) / Gas Range
Frigidaire MPF311PCWA Tap(v2) / Gas Range
Frigidaire MPF311PCWB Frg(v0) / Gas Range
Frigidaire MPF311PCWC Frg(v1) / Gas Range
Frigidaire MPF311PCWD Frg(v0) / Gas Range
Frigidaire MPF311PGWA Frg(v3) / Gas Range
Frigidaire MPF311PGWC Frg(v3) / Gas Range
Frigidaire MPF311PGWD Frg(v3) / Gas Range
Uni MPF311PGWE Universal/gas Range
Frigidaire MPF311SBDA Frg(v3) / Gas Range
Frigidaire MPF311SBDB Frg(v1) / Gas Range
Frigidaire MPF311SBDC Frg(v2) / Gas Range
Frigidaire MPF311SBDD Frg(v1) / Gas Range
Frigidaire MPF311SBWA Frg(v4) / Gas Range
Frigidaire MPF311SBWB Frg(v2) / Gas Range
Frigidaire MPF311SBWC Frg(v3) / Gas Range
Frigidaire MPF311SBWD Frg(v2) / Gas Range
Frigidaire MPF311SGDA Frg(v4) / Gas Range
Frigidaire MPF311SGDC Frg(v4) / Gas Range
Frigidaire MPF311SGDD Frg(v4) / Gas Range
Uni MPF311SGDE Universal/gas Range
Frigidaire MPF311SGWA Frg(v5) / Gas Range
Frigidaire MPF311SGWC Frg(v5) / Gas Range
Frigidaire MPF311SGWD Frg(v5) / Gas Range
Uni MPF311SGWE Universal/gas Range
Frigidaire MPF500PBDA Frg(v4) / Gas Range
Frigidaire MPF500PBDB Frg(v1) / Gas Range
Frigidaire MPF500PBWA Frg(v3) / Gas Range
Frigidaire MPF500PBWB Frg(v2) / Gas Range
Amana MPP227 Mwave - Cntrtp / Stand Alone
Amana MPP228 Mwave - Cntrtp / Stand Alone
Amana MPP228100L Mwave - Family Size (60 Hz)
Amana MPR215 Mwave - Cntrtp / Stand Alone
Amana MPR21510 Mwave - Mounted Over Range/wo
Amana MPR217 Mwave - Cntrtp / Stand Alone
Amana MPR219 Mwave - Cntrtp / Stand Alone
Amana MPS218-10 Range - S/c S/i Ddraft Gas
Amana MPS219-10 Mwave - Cntrtp / Stand Alone
Amana MPS225-10 Mwave - Family Size (60 Hz)
Amana MPS22510 Mwave - Family Size (60 Hz)
Amana MPS229-10 Mwave - Family Size (60 Hz)
Amana MPS22910 Mwave - Family Size (60 Hz)
Maytag MQC1557AEW Freezer - Vertical
Maytag MQC1557BEW Freezer - Chest
Maytag MQC2257AEW Freezer - Chest
Maytag MQC2257BEW Freezer - Chest
Maytag MQU1554AEW Freezer - Vertical
Maytag MQU1556AEW Freezer - Vertical
Maytag MQU1654BEW Freezer - Vertical
Maytag MQU1656BEW Freezer - Vertical
Maytag MQU2056ARW Freezer - Vertical
Maytag MQU2056BRW Freezer - Vertical
Maytag MQU2057AEW Freezer - Vertical
Maytag MQU2057BEW Freezer - Vertical
Amana MR-1 Range - S/c S/i Ddraft Gas
Amana MR-1W Mwave - Family Size (60 Hz)
Amana MR-2 Range - S/c S/i Ddraft Gas
Amana MR-3 Mwave - Family Size (60 Hz)
Maytag MR1031CWC Mwave - Cntrtp / Stand Alone
Maytag MR1031UWC Mwave - Cntrtp / Stand Alone
Maytag MR1031WB Mwave - Cntrtp / Stand Alone
Maytag MR1032BB Mwave - Cntrtp / Stand Alone
Maytag MR1032CBC Mwave - Cntrtp / Stand Alone
Maytag MR1032UBC Mwave - Cntrtp / Stand Alone
Maytag MR1033SB Mwave - Cntrtp / Stand Alone
Maytag MR1034CBD Mwave - Cntrtp / Stand Alone
Maytag MR1034CWD Mwave - Cntrtp / Stand Alone
Maytag MR1034UBD Mwave - Cntrtp / Stand Alone
Maytag MR1034UWD Mwave - Cntrtp / Stand Alone
Maytag MR1351WB Mwave - Cntrtp / Stand Alone
Maytag MR1352BB Mwave - Cntrtp / Stand Alone
Frigidaire MR15F1 Frg(v1) / Dehumidifier
Frigidaire MR15L1 Frg(v1) / Dehumidifier
Frigidaire MR15N1 Frg(v1) / Dehumidifier
  #2 (permalink)
Old 01-21-2013, 06:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Sounds like you did the voltage test wrong. Probably it suppose to be 120 VAC to each of the heating element terminals while the correct reading between the wires to both terminals should be 240 VAC.
You have to remove the wires from the heating element and measure the voltage between each wire and the ground and between the wires.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat or will stay on. All things have continuity, but heater element looks burned John Steele Dryer Repair 0 01-17-2013 08:17 AM
No Heat, No Timer, New Cycling Thermostat, New Fuse, Good Continuity Alakshak Dryer Repair 0 08-31-2012 06:56 PM
Whirlpool Elec - No Heat - Continuity OK JustinR Dryer Repair 7 11-23-2009 09:18 AM
Checking Continuity jdphoto Dryer Repair 1 04-14-2009 12:40 PM
Oven won't heat - good continuity jhd Oven Repair (including Ranges and Cooktops) 0 10-12-2008 07:27 PM
