| » Cannot Close Oven Door |
Model Number: CPS130 Brand: Dacor Age: More than 10 years
I bought this electric oven brand new in 1996. I have noticed two issues with the oven: 1) it has been increasingly difficult to close the oven door. The door gets stuck half way and I need to open the door fully and then push to close it. I think the hinges of the door need to be replaced. I wonder if I have to change the hinge receptacles as well. If so I would appreciate your advise re 2) In addition the racks support are lacking one screw and another two cannot be tighten. which means they are not supported. I am afraid they could no longer support the racks when dishes are cooking. I would appreciate your directing me on how to repair the door and porcelain support. Thank you very much Ads By Google Related Models |
Hello,
You have to replace both door hinges but I don't think that you have to replace the receptacles too. It's very rare issue. You did not mention what color is your oven. I found the part numbers for both stainless steel and black ovens. The door hinges are coming as a set of two. Also I found the part number for the rack support. The installation instructions are attached to the post but I'm not sure that the instructions for the door disassembly are good for this model. - The door hinge kit (SS models) Part number: 701035 - The door hinge kit (Black models) Part number: 701034 - The rack support kit Part number: 701038 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hello Gene,
Thanks so very much fo your prompt response and for the illustrations from the Dacor repair manual. Your opinion is very much valued and I will follow the advice of not changing the receptacles. It occured to me to change them because it is increasingly difficult to close the door and the hinges show signs of abrasion or harsh rubbing against something inside the cavity. The oven is White outside and black inside, hence I do not mind to have steel hinges that are black. The rack support issue seems more complicated. The structure is intact, but the screws that attach it to the oven inside walls cannot be tighten, and it seems that they just rotate without anything attached to them. So my question is what do they attach to? what kind of part is it? Thanks again for your good advise. i believe i am close to solving the problem Best graciela |
Hello Graciela,
In regards of the receptacles, you only the person who can determine if they really have to be replaced. Unfortunately I could not find any more information regarding the rack support. Dacor does not supply any technical information for non authorized servicers. Gene.
__________________
| Display Modes | |
| Oven door won't close | mhamil1017 | Oven Repair (including Ranges and Cooktops) | 4 | 04-28-2012 03:32 PM |
| Oven door won't close | cboneill | Oven Repair (including Ranges and Cooktops) | 0 | 04-10-2010 11:48 AM |
| Oven door will not close | dkoakes | Oven Repair (including Ranges and Cooktops) | 0 | 11-01-2009 12:10 PM |
| Cant close oven door | j_bates23 | Oven Repair (including Ranges and Cooktops) | 1 | 12-02-2007 05:22 PM |
| My Oven Door Latch Won't unlock so the door won"t close | Victorine Ravenell | Oven Repair (including Ranges and Cooktops) | 1 | 11-14-2007 10:40 AM |
