Discuss
Frigidaire oven
 in
Baking element no longer works. All other functions work. Could ir be a bad EOC or just a wire connection
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire oven
  #1 (permalink)
Old 01-20-2013, 09:54 AM
Junior Member
TimmyT23 is on a distinguished road
Default Frigidaire oven
Model Number: ES300   Brand: Frigidaire   Age: 5 - 10 years
Baking element no longer works. All other functions work. Could ir be a bad EOC or just a wire connection to the element?
Ads By Google
Related Models
Whirlpool ES5FHAXSA00 Refrigerator
Whirlpool ES5FHAXSA01 Refrigerator
Whirlpool ES5FHAXSB00 Refrigerator
Whirlpool ES5FHAXSB01 Refrigerator
Whirlpool ES5FHAXSQ00 Refrigerator
Whirlpool ES5FHAXSQ01 Refrigerator
Whirlpool ES5LHAXSA00 Refrigerator
Whirlpool ES5LHAXSA01 Refrigerator
Whirlpool ES5LHAXSA02 Refrigerator
Whirlpool ES5LHAXSB00 Refrigerator
Whirlpool ES5LHAXSB01 Refrigerator
Whirlpool ES5LHAXSB02 Refrigerator
Whirlpool ES5LHAXSQ00 Refrigerator
Whirlpool ES5LHAXSQ01 Refrigerator
Whirlpool ES5LHAXSQ02 Refrigerator
Amana ES5P2MR Room Air Conditioner
Amana ES5P2MS Room Air Conditioner
Whirlpool ES5PHAXSB00 Refrigerator
Whirlpool ES5PHAXSB01 Refrigerator
Whirlpool ES5PHAXSL00 Refrigerator
Whirlpool ES5PHAXSL01 Refrigerator
Whirlpool ES5PHAXSQ00 Refrigerator
Whirlpool ES5PHAXSQ01 Refrigerator
Amana ES614-2R Room Air Conditioner
Amana ES6142S Room Air Conditioner
Amana ES619-3R Room Air Conditioner
Amana ES619-3S Room Air Conditioner
Amana ES624-3R Room Air Conditioner
Amana ES6243R Room Air Conditioner
Amana ES6243S Room Air Conditioner
Amana ES6283L Room Air Conditioner
Amana ES6283L1 Room Air Conditioner
Amana ES629-3R Room Air Conditioner
Amana ES629-3S Room Air Conditioner
Amana ES6P-2AMR Room Air Conditioner
Amana ES6P-2AMS Room Air Conditioner
Amana ES6P2MR Room Air Conditioner
Amana ES6P2SPML Room Air Conditioner
Amana ES6P2SPMN Room Air Conditioner
Amana ES6P2SPMP Room Air Conditioner
Amana ES7-2MS Room Air Conditioner
Amana ES7-2MT Room Air Conditioner
Amana ES7P2MA Room Air Conditioner
Amana ES8P2MA Room Air Conditioner
Amana ES8P2MR Room Air Conditioner
Amana ES92MA Room Air Conditioner
Amana ES92ML Room Air Conditioner
Amana ES92MR Room Air Conditioner
Amana ES92MS Room Air Conditioner
Amana ESBFC16A Ref - Bottom Mounts
Amana ESBFC16AG Ref - Bottom Mounts
Amana ESBFC16B Ref - Bottom Mounts
Amana ESBFC16C Ref - Bottom Mounts
Amana ESBFC16C-A Ref - Bottom Mounts
Amana ESBFC16C-C Ref - Bottom Mounts
Amana ESBFC16C-G Ref - Bottom Mounts
Amana ESBFC16C-L Ref - Bottom Mounts
Amana ESBFC16D Ref - Bottom Mounts
Amana ESBFC16D-A Ref - Bottom Mounts
Amana ESBFC16D-C Ref - Bottom Mounts
Amana ESBFC16D-G Ref - Bottom Mounts
Amana ESBFC16D-L Ref - Bottom Mounts
Amana ESBFC16DA Ref - Bottom Mounts
Amana ESBFC16DC Ref - Bottom Mounts
Amana ESBFC16DG Ref - Bottom Mounts
Amana ESBFC16DL Ref - Bottom Mounts
Amana ESBFC16E Ref - Bottom Mounts
Amana ESBFC16EA Ref - Bottom Mounts
Amana ESBFC16EC Ref - Bottom Mounts
Amana ESBFC16EG Ref - Bottom Mounts
Amana ESBFC16EL Ref - Bottom Mounts
Amana ESBFC16L Ref - Bottom Mounts
Thermador ESC-30
Thermador ESC-31
Thermador ESC-34
Thermador ESC30B
Thermador ESC30B-01
Thermador ESC30CVB
Thermador ESC30CVB-01
Thermador ESC30CVWC
Thermador ESC30CVWH
Thermador ESC30WC
Thermador ESC30WH
Amana ESD341 Range - S/c S/i Ddraft Ele
Amana ESD342 Range - S/c S/i Ddraft Ele
Amana ESD343 Range - S/c S/i Ddraft Ele
Amana ESD344 Range - S/c S/i Ddraft Ele
Amana ESD345 Range - S/c S/i Ddraft Ele
Amana ESD349 Range - S/c S/i Ddraft Ele
Amana ESD356 Range - S/c S/i Ddraft Ele
Amana ESD359 Range - S/c S/i Ddraft Ele
Amana ESD379 Range - S/c S/i Ddraft Ele
Amana ESD394 Range - S/c S/i Ddraft Ele
Amana ESD395 Range - Std Mwave Ele
Amana ESD397 Range - S/c S/i Ddraft Ele
Maytag ESE9900 Stacked Laundry - Ele
General Electric ESF25KGTABB Refrigerator
General Electric ESF25KGTACC Refrigerator
General Electric ESF25KGTAWW Refrigerator
General Electric ESF25KGTBBB Refrigerator
General Electric ESF25KGTBCC Refrigerator
General Electric ESF25KGTBWW Refrigerator
General Electric ESF25LGRABB Refrigerator
General Electric ESF25LGRACC Refrigerator
General Electric ESF25LGRAWW Refrigerator
General Electric ESF25LGRBBB Refrigerator
General Electric ESF25LGRBCC Refrigerator
General Electric ESF25LGRBWW Refrigerator
General Electric ESF25LGRCBB Refrigerator
General Electric ESF25LGRCCC Refrigerator
General Electric ESF25LGRCWW Refrigerator
  #2 (permalink)
Old 01-23-2013, 04:17 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
The model number you give is the control board type not the units model number.
Find your model number - AppliancePartsPros.com
Could be either of the causes you cite but the most common cause is a bad element.
Unplug remove power from the unit.
Undo the screw/s holding the element to the back of the oven.
Gently pull the element into the oven.
remove one wire connecting the element.
Check the element for continuity, usually around 25 ohms.
Note be careful that the loose wire does not disappear into the back of the unit. I clip something (clothespin etc.) onto it just to be sure.
If the element is infinite ohms (open), replace it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How to test oven ignitor in Frigidaire oven Remi32 Oven Repair (including Ranges and Cooktops) 7 11-09-2012 04:17 PM
Frigidaire Double Wall Oven Upper No Broil Lower No Oven Jim Gaspar Oven Repair (including Ranges and Cooktops) 0 10-14-2012 12:50 PM
Frigidaire Gas Oven Frank47 Oven Repair (including Ranges and Cooktops) 0 05-09-2011 04:12 PM
Frigidaire Oven cshatto Oven Repair (including Ranges and Cooktops) 0 02-22-2011 08:43 AM
Frigidaire Double Oven/ Top oven not heating dross3491 Oven Repair (including Ranges and Cooktops) 6 12-14-2008 12:33 PM
