Discuss
Oven Will Not Heat
 in
Replaced Igniter Replaced Oven Control Gas Control Valve Checked Ohms OK What else can I do to get igniter working?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Will Not Heat
  #1 (permalink)
Old 01-18-2013, 01:14 PM
Junior Member
badams1214 is on a distinguished road
Default Oven Will Not Heat
Model Number: JGSP44WEY6WW   Brand: GE   Age: 5 - 10 years
Replaced Igniter
Ads By Google
Related Models
General Electric JGSP44WEY6WW Gas range
General Electric JGSP44WEY7WW Gas range
General Electric JGSP44WEY8WW Gas range
General Electric JGSP48BH1BB Gas range
General Electric JGSP48BH2BB Gas range
General Electric JGSP48BH3BB Gas range
General Electric JGSP48BH4BB Gas range
General Electric JGSP48BH5BB Gas range
General Electric JGSP48BH6BB Gas range
General Electric JGSP48CH1CC Gas range
General Electric JGSP48CH2CC Gas range
General Electric JGSP48CH3CC Gas range
General Electric JGSP48CH4CC Gas range
General Electric JGSP48CH5CC Gas range
General Electric JGSP48CH6CC Gas range
General Electric JGSP48SH1SS Gas range
General Electric JGSP48SH2SS Gas range
General Electric JGSP48SH3SS Gas range
General Electric JGSP48SH4SS Gas range
General Electric JGSP48WH1WW Gas range
General Electric JGSP48WH2WW Gas range
General Electric JGSP48WH3WW Gas range
General Electric JGSP48WH4WW Gas range
General Electric JGSP48WH5WW Gas range
General Electric JGSP48WH6WW Gas range
General Electric JGSS03EH1 Gas range
General Electric JGSS03EH2 Gas range
General Electric JGSS03EH3 Gas range
General Electric JGSS03EJ1 Electric range
General Electric JGSS03PH1 Gas range
General Electric JGSS03PH2 Gas range
General Electric JGSS03PH3 Gas range
General Electric JGSS03PJ1 Gas range
General Electric JGSS05BEA1BB Gas range
General Electric JGSS05BEA2BB Gas range
General Electric JGSS05BEA3BB Gas range
General Electric JGSS05BEA4BB Gas range
General Electric JGSS05BEA5BB Gas range
General Electric JGSS05BEA6BB Gas range
General Electric JGSS05BEA7BB Gas range
General Electric JGSS05BEH1BB Gas range
General Electric JGSS05BEH2BB Gas range
General Electric JGSS05BEW1BB Gas range
General Electric JGSS05BEW2BB Gas range
General Electric JGSS05GEJ1 Gas range
General Electric JGSS05GEJ2 Gas range
General Electric JGSS05GEK1 Gas range
General Electric JGSS05GEK2 Electric range
General Electric JGSS05GEN1 Gas range
General Electric JGSS05GER1 Gas range
General Electric JGSS05GER2 Gas range
General Electric JGSS05GER3 Gas range
General Electric JGSS05GER4 Gas range
General Electric JGSS05GER5 Gas range
General Electric JGSS05GEV1BB Gas range
General Electric JGSS05GEV3BB Gas range
General Electric JGSS05GPJ1 Gas range
General Electric JGSS05GPJ2 Gas range
General Electric JGSS05GPK1 Gas range
Maytag JGT2424 Commercial Cooking
Maytag JGT2436 Microwave Oven 1.8 Cu. Ft.
Maytag JGT2442 Commercial Cooking
Maytag JGT2448 Commercial Cooking
Maytag JGT2454 Commercial Cooking
Maytag JGT2460 Commercial Cooking
Maytag JGT2472 Commercial Cooking
Maytag JGT2484 Commercial Cooking
Jenn-Air JGW8130ADB Walloven - S/c Gas
Jenn-Air JGW8130ADW Walloven - S/c Gas
Jenn-Air JGW8130DDB Walloven - S/c Gas
Whirlpool JGW8130DDB12 30" Built - in Gas Single Oven
Maytag JGW8130DDB12 30" Built - in Gas Single Oven
Jenn-Air JGW8130DDW Walloven - S/c Gas
Whirlpool JGW8130DDW12 30" Built - in Gas Single Oven
Maytag JGW8130DDW12 30" Built - in Gas Single Oven
Jenn-Air JGW9130ADB Walloven - S/c Gas
Jenn-Air JGW9130ADW Walloven - S/c Gas
General Electric JHC56*D1 Hi-low range
General Electric JHC56*VA Hi-low range
General Electric JHC56*VB Hi-low range
General Electric JHC56G*D1 Hi-low range
General Electric JHC56G*D2 Hi-low range
Maytag JHP1060 Commercial Cooking
Maytag JHP112 Commercial Cooking
Maytag JHP212 Commercial Cooking
Maytag JHP224 Commercial Cooking
Maytag JHP336 Commercial Cooking
Maytag JHP424 Commercial Cooking
Maytag JHP448 Commercial Cooking
General Electric JHP56*D1 Hi-low range
General Electric JHP56*V8 Hi-low range
General Electric JHP56*VA Hi-low range
General Electric JHP56G*C1 Hi-low range
General Electric JHP56G*D1 Hi-low range
General Electric JHP56G*D2 Hi-low range
General Electric JHP56G*D3 Hi-low range
General Electric JHP56G*H2 Hi-low range
General Electric JHP56G*J1 Hi-low range
General Electric JHP56G*J2 Hi-low range
General Electric JHP56G*J3 Hi-low range
General Electric JHP56G*M1 Hi-low range
General Electric JHP56G*V6 Hi-low range
General Electric JHP56GN1 Hi-low range
General Electric JHP56GN2 Hi-low range
General Electric JHP56GN3AD Electric range
General Electric JHP56GN3WH Electric range
General Electric JHP56GN4AD Electric range
General Electric JHP56GN4WH Electric range
General Electric JHP56GN5AD Electric range
General Electric JHP56GN5WH Electric range
General Electric JHP56GN6AD Electric range
General Electric JHP56GN6WH Electric range
General Electric JHP56GN7AD Electric range
General Electric JHP56GN7WH Electric range
General Electric JHP56N*K1 Hi-low range
General Electric JHP56N*K2 Hi-low range
General Electric JHP56N*K3 Hi-low range
General Electric JHP56N*K4 Hi-low range
General Electric JHP56V*K1 Hi-low range
General Electric JHP56V*K2 Hi-low range
  #2 (permalink)
Old 01-18-2013, 01:21 PM
Junior Member
Default
Replaced Igniter
  #3 (permalink)
Old 01-18-2013, 01:30 PM
Junior Member
Baudretsch is on a distinguished road
Default
Assuming that the ignitor doesn't glow, check for continuity through the ignitor. If it tests ok, check for voltage to the ignitor. If there is no voltage, trace it back, you'll find the bad part.
If the ignitor does glow, it still could be a bad one. It needs to pass a certain amount of current to signal the gas valve to open.
Good Luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No heat and leads to oven heat element only showing 110volts nobull1466 Oven Repair (including Ranges and Cooktops) 7 06-07-2012 11:23 AM
Oven won't heat up to pre-heat setting tmilam Oven Repair (including Ranges and Cooktops) 0 04-24-2011 04:48 PM
Frigidaire FEFL79DSD ES340 Electric Range cooktop won't heat and oven wont heat dsumption Oven Repair (including Ranges and Cooktops) 3 04-04-2011 05:03 PM
Wall oven will not heat/re-heat properly dottavio Oven Repair (including Ranges and Cooktops) 0 01-07-2010 09:47 AM
Oven/clock Control Panel is no longer lit but oven does heat. jthomas@abrakadoodle.com Oven Repair (including Ranges and Cooktops) 1 12-05-2009 04:07 PM
