| » whirlpool fault codes |
Model Number: RBS275PRQ00 Brand: Whirlpool Age: More than 10 years
Starts to heat up then I think shuts off and dispalys E2-F3 code. How should I proceed?
Hello,
Open the control panel. Locate the plug P3 at the control board and unplug it. Measure the resistance between the wires connected to the P3-1 & P3-2 pins. The normal reading suppose to be about 1100 Ohms at the room temperature. If the reading is incorrect, replace the oven temperature sensor. If the reading is correct, replace the oven control board. - The oven sensor Part number: W10131825 - The oven control board Part number: W10340935 Here are the breakdown diagrams and Parts for Whirlpool RBS275PRQ00 Wall Oven - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Hey thank you for the response. That appears to be the process... check the sensor, if it's good then replace the control board. What is the role of the Thermal overload device in all this if any? After installing a new control board, the tech sheet discusses setting the oven for the appropriate interior size. Are there any other concerns or things to be aware of after a new board install? Thanks again.
Quote:
I don't think there is anything else to worry about. Gene.
__________________
| Display Modes | |
| Whirlpool Cabrio getting F50 F51 fault codes | dbergquist | Washer Repair | 2 | 01-27-2012 06:36 PM |
| Whirlpool oven fault codes E3 and F1 | txtrisha | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2011 07:51 PM |
| fault codes | shepp59 | Oven Repair (including Ranges and Cooktops) | 3 | 11-18-2010 05:20 PM |
| F1-1, F1-2, F3-2 Fault Codes | pjc97009 | Oven Repair (including Ranges and Cooktops) | 0 | 11-15-2010 01:47 PM |
| Kenmore/Whirlpool Fault Codes??? | sgo529 | Oven Repair (including Ranges and Cooktops) | 3 | 11-05-2008 11:32 AM |
