| » GE Built-In Gas Oven Won't Work Even After Replacing Parts |
Model Number: JGRP16GEP1BG Brand: GE Age: More than 10 years
Hello everyone,
Not sure if this is where I'm supposed to post but was wondering if you guys could help me. I have a GE built-in gas oven which had a weak ignitor glow so I decided to replace it with a new ignitor replacement part. However, after replacing the 2 ignitors (bake & broil) and one temperature sensor--it still will not turn on. I don't think it's the gas valve because first the ignitor has to glow red before the gas valve can turn on according to what I've read. But now, the ignitor doesn't glow at all so I'm not quite sure what's wrong. When I replaced the parts, I put all the wiring back in its original position and everything. Any insight would be super helpful! Thank you in advance for all your help! Ads By Google Related Models |
You wrote that you replaced the ignitor "because it had a weak glow". But it did glow. Then, either the wiring wasn't connected correctly or the new ignitor is faulty (rare, but it does happen, the older style silicon carbide ignitors are very fragile, and the smallest crack will do it).
You could try using a volt/ohm meter to first check continuity through the ignitor and, if you find that the ignitor conducts, test the power coming to the ignitor. Good Luck |
To clarify, the re-wiring may be faulty. It happens to the best of us. So check that first. Check for broken insulation shorting to the body of the oven too.
Last edited by Baudretsch : 01-17-2013 at 10:32 PM. Reason: Double post, I'm new to posting on this site. |
| Display Modes | |
| Replacing broil ignitor on Amana built in oven | StephenDashiell | Oven Repair (including Ranges and Cooktops) | 1 | 08-27-2010 07:17 AM |
| GE Gas Oven will not work even after replacing the Igniter | revbobmartin | Oven Repair (including Ranges and Cooktops) | 0 | 01-21-2010 01:07 PM |
| GE Gas Oven will not work even after replacing the Igniter | revbobmartin | Oven Repair (including Ranges and Cooktops) | 0 | 01-21-2010 01:03 PM |
| GE Built-in Oven Key number keys won't work | SGOFFMAN | Oven Repair (including Ranges and Cooktops) | 1 | 01-19-2009 03:27 PM |
| Latch release on built in oven won't work | Richentam | Oven Repair (including Ranges and Cooktops) | 1 | 12-18-2008 02:54 PM |
